[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by macavita View Post
Can you give me a link for the files you used?
https://forum.xda-developers.com/sho....php?t=3034811
Originally posted by teters01 View Post
I just installed this rom now but the remote is not working. Luckily remote from my tv works
For the remote to work on other boxes you would need some files from that boxes firmware
from system/etc
remote.conf
remote-mouse12.tab
remote-mouse31.tab
from usr/keylayout
Vendor_0001_Product_0001.kl
Originally posted by mykola7619 View PostThank You for your job! Is it possible back youtube from old version this one not work with air mouse??? thank YouLast edited by tillaz87; 24 November 2017, 15:52.
Originally posted by macavita View Posthow can i change the wallpaper ?
Name your desired wallpaper to bg_custom.png (must have .png extension)
From the rom you need to take system/priv-app/AtvCustomization/AtvCustomization.apk
Put it on your pc and open it with WinRar (not extract)
Open res/drawable-xhdpi-v4/
Drag and drop the new wallpaper in here
Done, add it back where you got it overwriting the old one, set perms.
reboot and clear data for leanback launcher
here is a zip to flash for stock wallpaper
Originally posted by Philbra View PostHI Tillaz
when you write in the installation “ut your free to try flashing the zip in recovery without wipe to update (from previous version)”
do you mean a prior “tillaz” installation or any other installation such as a last magendanz one for exemple ?
thank you by advance
philippe
I love the implementation but it does not fix wifi. The Nexus ATV by Guest has nice wifi implementation. I presume he included a custom kernel and some AMPAK drivers for the AP 6255 ...I also think his use of the all in one shiningworth firmware makes the general wifi and 3d graphics performance better (41k on Antutu).
Great work, but you should really move from using Beelink firmware
Originally posted by cbm View PostI love the implementation but it does not fix wifi. The Nexus ATV by Guest has nice wifi implementation. I presume he included a custom kernel and some AMPAK drivers for the AP 6255 ...I also think his use of the all in one shiningworth firmware makes the general wifi and 3d graphics performance better (41k on Antutu).
the all in one OEM firmware has suport for all wifi chips already included but has BT issues from what i read.
benchmarks dont mean much to real life use. OEM are caught cheating in them all the time.. oneplus to be the latest. So i dont take them to seriously considering I can run "bully" (Xbox 360 android port) just below 30fps
Each to thier own though its good we have choices
There are currently 1270 users online. 2 members and 1268 guests.
