[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    I have rom to superceleron no android tv V8 . I want test your rom with android tv.
    I have just flash with sd card the 705 ?
    Do you have a link to 705 Thanks?
      beelink removed 705 for some reason, but the only real difference was libamplayer.so the rest of system was identical.
      You would need to use 707
      Here is a zip to flash after you have installed 707 and this patch ROM it makes your base firmware identical to 705
        tillaz87 : SPDIF passthru works?
          Please how flash just patch..
          Where is TWRP on your ROM ?
            First post explains how to install.
            or this http://freaktab.com/forum/tv-player-...538#post685538
              I install your rom but how install patch 705.zip?
                ah right, download a reboot app reboot to recovery and flash the zip
                  Ok how reboot to recovery mod ?
                    https://play.google.com/store/apps/d...eboot&hl=en_GB
                    infact that app is open source I might remove some stuff and add it to bottom of launcher as a power button
                      if i want to use netflix , i will have to unroot?
                      do i need to patch to 705 or 707 is enough ?
                        Hello
                        how to uninstall the patch and return with version 705NO
                        Thank's
                          Thank you @tillaz87 Everything works perfectly
                          However I did not apply your pach I stayed in 707NO and everything works fine for me.
                          Do you have another launcher to advise me that will work because all launchers like HAL... do not stay by default?
                          And you how add a icon or widget for shutdown (as rom to Magendanz)
                          Thank you
                            Thank you
                            you need to add your new launcher to system/app set permissions then delete leanback launcher
                            Thank you
                            Will be in next update with reboot recovery option
                              Hello
                              I installed this rom and for now everything works with or almost
                              no dts or dolby on netflix but I think it's normal
                              I wanted to test Amazon's primevideo the app starts but the movies or series do not start.
                              If you have an idea
                              in any case, thank you for your work
                              Charles
                                Originally posted by CHARLUS60 View Post
                                Hello
                                If you have an idea
                                Charles
                                think its DRM protected like the tv netflix app
                                I was sent this as it was said to work https://drive.google.com/open?id=0B0...2dkR1RzVTgyTkk
