[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    since i install this MOD i cant recieve write approve to my SD card (sandisk 32 gb). i tried to unmount and to format but nothing help
      I have 128gb card and its working fine try using "es file explorer" its what i use
        tillaz87 Hi, I have just downloaded the 707NO firmware for the S912. However the IMG's name is LTM8830. But the wifi chip is called QCA9377. This is not conform with the file's name. Can I use it for the S912 serial GT1?
          Yes
          only thing diff in 707 was libamplayer.so and it could be causing stutter in kodi
            Originally posted by tillaz87 View Post
            Yes
            OK, then I stay with 705
              Here is v7 which uses M8S_PRO+ framework. its here to test and tell me what you think. stick with this or beelinks ?
              Notes:
              This update wipes your data after install.
              For power off menu on this firmware you need to hold power button, normal press is sleep.
              You need to be running stock 7.1.2 (any beelink version) or any previous version of this patch
              • M8S_PRO+ framework = fixes action bar and more
              • Color space settings added to display/resolution (top)
              • build.prop changes (Gaming performance?)
              • Fixed screenshot
              • Cleaned up some bloat
              • Compatible with 707ON
              • Script flashes TWRP then boots recovery for auto install
              • SuperSU is now inside install zip
              Use the script for this install
              1. Download the Files below and copy them to the Internal Storage (script is made for internal as the mount is always /sdcard)
              2. Install the terminal.apk or download one from the market
              3. Open the terminal app and type the commands below pressing enter after each
              Code:
              su
              Code:
              sh /sdcard/1
              Install zip
              Script
              Recommended
              This app to backup all apps and batch install without user input
              Xposed framework and obb on sd module if you use games and have sdcard
                Notes:
                • Fixed screenshot
                Code:
                su
                Code:
                sh /sdcard/1
                Install zip
                Script
                Recommended
                so this 1 has diffrent firmewaer for the post on pag 1?
                because i tested @magendz ATV on my gt1 ultimate g912 and it was ok, real fast, just 1 thing botherd me, the colors on the screen were to gray and not sharp, so i reverted back to the stock
                rom from beekink (113_mo), with the bootvideo=1 tweek on the build prop, and the colors arw fine.
                  this only has different framework, the rest is still stock beelink
                  it can also change colour space settings. at 1080p i use RGB 10bit this looks good but at 4k i use 444 10bit this looks even better
                  I might even revert to beelink framework depending on what people think
                    Good evening
                    I am testing this rom
                    the wifi works for this it must be activated via advanced parameter
                    however it is not detected by some application that need it
                    I feel that the configuration of the screen is lost at each reboot
                    Dts and dolby ok in local network
                    does not work for plex and netflix
                    Nothing else for now I continue my test tomorrow night
                    thank you for your work
                    Charles
                      WiFi should work exactly like stock as its untouched by this patch. my WiFi is actually better than ever with 705 as base
                        Updated this to use framework from latest firmware for M8S_PRO_L-ota-20171109.180937.V0928 this
                        Will post links soon
                          hi
                          work fine for me on beelink gt1
                            someone is able to use netflix?
                            i receive error
                              Please link to flash ma GT1 wiht 705NO.. no link on Beelink Website :
                              GT1 705NO standrad/ultimate 2G+16G/2G+32G/3G+32G A912/AX12(AP6255)
                                beelink removed it for some reason, the only real difference was libamplayer.so the rest of system was identical I can provided a zip to revert that though to one from 705
