[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tenoce View Post
Hi Tillaz, any suggestion for G or S series? There's only 703 available. Could I use that with your v6 script?
Originally posted by xw0lf View PostNice... so.... i must reinstall all apps again.... ohhh
Should also be using xposed for obb on sd if you have games as well. this means the big files are stored on external storage so they survive any wipes or flashing
It's what I do anyway
tnx tillaz...
feq questions:
1) does bt settings now work or not work, in way to connect bt controllers (virtual ones?)
2) it's possible for someone to make zip/twrp/cwm version of 705 rom... to apply from twrp as update, and then v6.... this is easier than flash all from zero, and apply v6 + all apks?
Originally posted by xw0lf View Posttnx tillaz...
feq questions:
That's easier for you, but not the person making the zip and uploading it lol beelink probably wont release a 706, they wont have any customers left by then
Why you think that? I no see logic, for now..
You think beelink will stop with updates anyway or only if someone make zip update of their img update?
Curently, beelink ruin their status with unfinished unstable beta rom releases.... people can stop buying their products if they not improve software faster and better... good hardware is useless without good software....
Or maybe we need aosp/lineage rom, besides official one?
Originally posted by xw0lf View PostWhy you think that? I no see logic, for now..
to be fair they have released like 6 updates already and that's rare to me, as huawei and zte used to give you 1 then forget about the device and its issues..
its obvious to me beelink are not very skilled looking at what thy are building, same goes for amlogic.. as most of the problems are amlogics source
so i wont be surprised if the updates stop soon as amlogics new soc cant be fare away nowLast edited by tillaz87; 01 November 2017, 06:09.
Originally posted by tillaz87 View Post
It should work yes but 705N0 for them should be coming soon. only thing that might not fully work is droid settings as it was changed around 704 I think
There are currently 2332 users online. 1 members and 2331 guests.
