[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Do you mean 3D movies ?
Main reason is because the root method beelink include in stock rom is dangerous. it has no app to handle root access meaning any rouge app could do things without you knowing
also if you just install superSU.apk and try to update the binary it will soft brick, so flashing the zip is highly recommended.
I cant just remove their root method ether as the install needs root to run, so its down to the user
Will have a look, i have CEC turned off
first boot should be no longer than 10 mins, I would recommend factory reset. script might of been cut short at the end.
The Youtube app is intentionally not updated, this means people who hate the new youtube are not stuck with it, people who want it updated can update
I would recommend factory reset. been running this for a while not had ether of those issues.
3D games are not working, yesterday I side loaded 3
3c tools and did some tuning (1 click uptimise) gave some improvements.
Originally posted by BPENL View Post
First this is the first ROM what makes this box usable, kodi and Netflix working.
Gta 3
vice city
San Andrea's
Hotline Miami 1 & 2
Tomb raider 1 & 2
bully
Minecraft
Shadogun
flats
All ps1 games with emulator
That's just a few off the top of my head that I tested on this box
Only game I tried from market that lagged so bad it was unplayable was radiation island. The box has quite poor hardware for games but was very surprised at the games it played.
If you are side loading games make sure your using mail cache or they won't work
What 3D games are you having trouble with?
That's very strange if you look at my screenshots on first post you can see I have a lot of 3D games installed that are not supposed to be supported which all work great
Gta 3
vice city
San Andrea's
Hotline Miami 1 & 2
Tomb raider 1 & 2
bully
Minecraft
Shadogun
flats
I tried warplane Beach buggy, city racing asphalt street racing.
Will try a few of your games.
I did not side load games. Just sd install 3c toolbox and some other apps after app extract from phone
Regards
Sometimes m'y box dont boot ,stay on Google screen
I have tried to reset factory setting in Android TV , no working
I have tried to format and reset setting un trwp
No working
may ne i have to install another time supersu? Or supersu is often installed ?
Édit : on official beelink forum many people have boot problems with 704n roms!
Tillaz are you un 704n or 703n roms?
Can i flash the official 703n roms with usbburning tools other your Android TV roms?Last edited by sarkaron; 12 October 2017, 23:42.
I've got tje ax12 version, Ib blamed it on that.
Regards
Originally posted by sarkaron View PostSometimes m'y box dont boot ,stay on Google screen
No working
Originally posted by tillaz87 View PostHere is an example of what beelinks root method can do :/ this is why i say to flash the zip
http://www.bee-link.com/Beelink-22487-1-1.html
I this post i can read some people brick their device after install super su !
And you say i have to flash the super su ZIP file?
So i have to flash the After install android TV with trwp that right?
Step 1 : install official 703no or 704no
Step 2 : install Android TV from script
Step 3 : install super su ZIP file in recovery
That right?
Somes problems with 704NO
http://www.bee-link.com/forum.php?mo...astpost&page=4
I try 703no this afternoon
I'm fell like a newbe ... SorryLast edited by sarkaron; 13 October 2017, 08:27.
OK , i'm may ne vert stupid but there something i dont understand!
That right?
That's correct. The zip removes beelinks root and patches boot.img for root and then superSU works as it should
I try the 703NO rom this afternoon with your android tv rom , may be no boot problems like that!
Thanks for your patience
After install 703N0 rom , flash android tv, the zip of supersu et an factory reset all work like a charm, boot is fast each time!!
If you have boot problems with 704N0 try 703N0
A last question for you tillaz , after a factory reset in android tv, i have to install again supersu zip or remains installed?
thx
what happens when you try to launch the games that don't work? I tried beach buggy from market it works,your version will have no impact on gaming its just wifi chip and ram
Nedflix/Kodi working good, After I did a 1 click optimization from 3C tools pro speed was very good.
I'm a bit afraid that I'm stuck with a Hardware problem, but can't see where its coming from.
Didn't have the time to test with your suggested games.
Enjoy your day.
There are currently 4005 users online. 1 members and 4004 guests.
