[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Philbra View PostHello,
Good question; I have just received the GT1 ultimate with the last F/W and the serial is AX12 xxxxx.
I see so many posts that say this H/W is very sensitive to bricking that I definitively do not know which ROM I have to use to have android TV
Please help
Philippe
The AX12 uses the AP6255 WiFi chip. Can anyone verify?
I updated this rom directly from 704NO stock rom my AX12 without any trouble.
All the bugs I could have with the stock rom (Light home, Youtube, freeze...) are solved with this rom.
From the update (2 or 3 weeks) It works like a charm.
Really thank you tillaz87 to enable us to use a sucking device (GT1 Ultimate AX12) as it should normally run!
PS: Maybe I can describe a bug I encoutered when I updated it from stock rom for other people.
When I launched the update, after a while, the device stuck with Google animation.
I beleive the device was running and I let it for all night long.
When I woke up, it was still on the animation. I shut off the power supply and connected it again and that's all! All is running still this day!
Originally posted by Gryfter View Post
I'm in the same boat. Judging by this post:
BRYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
By flashing trough Burn Card Maker you can easily downgrade.
IN this ROM for me, Nedflix working (Installed the version from one of the posts), KODI working, just no 3D at all (as with every ROM I found)
It is connecting with my GameSir.
I really hope Beelink brings a ROM where is problem is solved.
I have install official Android 7.1.2 and after i have install Android TV 7.1.2 rev5 , i'm now on Android TV
Now i have to install supersu in recovery mod with install.ZIP right?
Why i have to do that if all works now?
Thanks !
Answer to my question : some app dont work properly if you dont install supersu after instaling Android TV ( like molotov TV)
After install Android TV install supersu in recovery mod with install zipLast edited by sarkaron; 11 October 2017, 22:40.
Originally posted by tillaz87 View Post
True Android TV
Is your box a GT1 ?
- To switch off Box and TV I use Off from the TV (then the GT1 moved to sleep: Led switch off)
- To switch on Box and TV I use On from the Box (GT1 led switch on the then TV switch on) - At that time I got the issue with Power menu prompt
After test i have two little problems with Android tv
1st: sometime the box dont boot ( stay on Android boot screen) i have to unplug it to restart
2 : in kodi some movie starts with a black screen (1080 p but not all) and i have to fast forward and the picture come
Sorry for my poor english!
And thx a lot for this work good job at all!
Originally posted by BPENL View Postjust no 3D at all (as with every ROM I found)
Originally posted by sarkaron View PostI have install official Android 7.1.2 and after i hav e install Android TV 7.1.2 rev5 , i'm now on Android TV
also if you just install superSU.apk and try to update the binary it will soft brick, so flashing the zip is highly recommended.
I cant just remove their root method ether as the install needs root to run, so its down to the user
Originally posted by ades View PostYes a GT1, just to be more precise HDMI CEC is configured for On and Off:
Originally posted by Piwek View PostI have problem with this firmware, very long booting time over one hour... YouTube app after uptade back to normal version. I have gt1 ultimate.
The Youtube app is intentionally not updated, this means people who hate the new youtube are not stuck with it, people who want it updated can update
Originally posted by sarkaron View PostAfter test i have two little problems with Android tv
same for BT transfer. although its much faster to send files using wifi with es file explorer this is how i transfer files its 20x faster
https://play.google.com/store/apps/d...d.pop&hl=en_GB
EDIT:
You can actually also use the share option to send via Bluetooth with es file explorer aswell
There are currently 3316 users online. 0 members and 3316 guests.
