[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    I just started using your rom on H96 pro which works great. I was using SC rom GT1 2 6.0.2 which very stable and I decided to test out 7.1.2 GT1.
    SC rom had the remote configured for games, so beach buggy, skyforce worked by the remote. I normally use PS43 pad via bluetooth six axis apk or xbox pad. I could power it off by remote and as replacement I am using reboot app with r8 keyboard/mouse pad.
    Can you include browser app on a fresh install rom because the playstore didn't have many good browser apps. This once i used v5 script.
      hi,
      * do you add google dns server ip to BuildProp file?
      * NetFlix appnot work via Google Play but old version apk file work but not stable, sometimes give error message?
      * I plug pc keybord, work but i can not change to Turkish language layout
        Hello i have the gt1 A912 and just the original remote.
        Can i use this package and the recovery whithout Bluetooth or usb mouse or pad ???
        What is the more safe method to flash the 7.1.2 because i have a old firmware.
        Thank's
          Post removed.
            Hi Tillaz,
            I just flashed the latest 704N0 for the 9377 wifi chipset with your V5 and the orientation option under the Droidsettings menu is not working. It crashes and the options do not appear at all.
              "Problem" solved. I installed the 'Set orientation' app form play store and the orientation setting under the DroidSettings option is working again.
                Hi ! I have flasher my box cooleme with firmware GT1 V0321 android 7.1.1 nexus and it works well! can I flasher with the GT1 722? thank you
                  Beelink love to be confusing lol new firmware version of the already released 704N this one been called "stable" http://www.bee-link.com/Beelink-23776-1-1.html
                  will look over this today or tomorrow and update accordingly
                  Why not call it 705N Beelink? or is it the same firmware, just decided its stable lol
                  • Guest's Avatar
                    Guest commented
                    Editing a comment
                    I thought this was just a refresh for QCA9377/LTM8830 wireless chipsets. The previous GT1_704N0 was AP622 only.
                  Haha its far from stable then codec issues and issues with 60fps make me want to go back to the shield :/
                    Hey tillaz87 it impresses me how people know this stuff..I was at offlical beelink 7.1.2 and flashed your v5 via usb all is great ..working quick question when it boots up still looks like stock did I do something wrong ??doesn't look like the images you posted. Where any apps supposed to be installed?? like youtube 4k?? I don't see anything.. when I goto info shows 7.04
                      tilla87
                      just installed your v5 and looks gorgeous thanks!
                      Is there away to change the apps icon on the homepage? everytime I try it, it show the bin to uninstall
                        if I add those 3 files will my device be considered rooted?? and why on kodi using Ares to optimize I only have very little ram free?? I have gt1 2g/16 my old nexbox was quad core 2g and showed 30% more ram is this because the android 7 is ram hungry??
                          Is this solution compatible with other s912 devices? Or is it strictly GT1 / H96?
                            yes, it will be rooted but it can easily be removed if you don't want root.
                            Having little held in ram will only slow stuff down.
                            Using aggressive low memory killer settings to always have 1GB free makes having 2GB pointless, as it its been stopped from doing its job at full potential.
                            to much free ram is just wasted ram. multitasking would also be useless.
                            Android default settings do a good job at swapping stuff in and out of memory so people shouldn't be worried about free ram unless memory leak which I'm unaware of.
                            I have over 40 games and apps installed and all running fine never had anything killed while in use.
                            the files need to be on internal storage, unless you know what your doing and change the command to other directory. but if it boots up without google splash screen it didn't work.
                            tilla87
                            long hold on an icon then you can move them about, changing the look of icons is not possible on tv launcher
                              Installed this rom on my GT1 Ultimate. Works like a charm! Great job tillaz87 thanks!
                              Only thing that annoys me is the lack of apps for atv supported by google. Have to sidelode all the non atv apps instead of a direct google play download.
