had to factory reset
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
- it still play only SD quality
- some menu won't work, e.g, I can't access the subtitle on/off, style menu. So no subtitle.
update: submenu to set subtitle does work.Last edited by bthoven; 04 August 2017, 16:30.
Originally posted by bthoven View Post
Thanks. I just got an apk file from a website (sorry I can't remember). After installing it, run, it asked for downloading a video player which I can install sucessfully. It can play Amazon Prime video, with some limitation:
After using this app and applying some of the settings all youtube videos are locked to 720p max.. but display res is still 4k. even after uninstalling the app and rebooting..
Today I've tried to connect GT1 to external Bluetooth speaker (Mi Speaker 2015) and got Bluetooth FC repeatly, here is adb logcat (I think conflict between stock Bluetooth.apk with ATVRemote BT service). Revert back to stock rom solve that bluetooth connection problem (which ATV UI also gone).
Originally posted by longnt View Post
I've found author of that tool also make a thread on freaktab.com
My box serial number start with G912 so I think my wifi chip is 9377.
Stock firmware is A9377 STOCK 7.1.2 , I've noticed that build is NHG47L.20170712 while your build on ATV patch is NHG47L.20170713.
To pair in stock, I simple open classic Android settings.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by longnt View PostMy box serial number start with G912 so I think my wifi chip is 9377.
qcom.bluetooth.soc=rome_uartAttached Files
In stock rom, with TV Settings, I can unpair and pair like stock settings. Here is logcat. I think Mi Speaker 2015 is an odd case because that speaker add a lot services to system (which some services maybe conflict with ATVRemote) while other bluetooth speakers just add only one service to enable bluetooth speaker.
About Youtube 60fps freezing issue, did you try new Youtube TV 2.0 ? I've playing 4k 60fps videos smoothly with new version while old version 1.3 have freezing bug at 1080p60 after a few seconds.
I've playing 4k 60fps videos smoothly with new version while old version 1.3 have freezing bug at 1080p60 after a few seconds. But new version can't select Optimal Resolution, sometimes it's max at 1920 x 1080, sometimes it's 3840 x 2160...
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 1647 users online. 1 members and 1646 guests.
