[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
1) BT headphones connected without any other BT devices = Works fine
2) BT headphones connected with BT gamepad = Audio stutters constantly
tell me if this is same for you, and anyone else. plus your wifi chip if not.
Guest
No, it doesn't seem to matter for me if no other devices are connected when running GT1_7050_QCA9377. My Bluetooth audio is consistently bad.
I don't know, I want to like this update as it appears to be the smoothest so far. However, it may be just my box but i keep getting frozen screen problem. (No way to wake up)
Happened 3 times during hevc playback, and happened once when nothing was on. I might try a redownload and reflash later to see if it solves the problem.
Originally posted by Magendanz View PostNo, it doesn't seem to matter for me if no other devices are connected when running GT1_7050_QCA9377. My Bluetooth audio is consistently bad.
Originally posted by tillaz87 View Post
got a link? this must be QCA9377 olny, I will make a zip
or directly:
Guest
Originally posted by tillaz87Here is BT patch for QCA9377 (others are ok)
BT_QCA9377.zip
script
flash in recovery
or
put files on root of internal storage then from terminal
su
sh /sdcard/3
will auto reboot and flash then reboot
Credit to manvel
Sent from my SM-G955W using Tapatalk
Guest
Originally posted by Orion696I flashed the file in TWRP, my device Paired successfully then no stuttering for 30 seconds i was so happy I tough it was fixed... but then the stuttering came back..
Originally posted by Orion696 View PostI flashed the file in TWRP, my device Paired successfully then no stuttering for 30 seconds i was so happy I tough it was fixed... but then the stuttering came back..
try this one, forgot this is 64bit link QCA9377 (others are ok) flash in recoveryLast edited by tillaz87; 08 November 2017, 02:17.
There are currently 2901 users online. 0 members and 2901 guests.
