[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Tell your V8 firmware. will AFR? "When playing video content at different frame rates (23.97Hz, 24Hz, 25Hz, 30Hz, 50Hz), if the player does not automatically switch to the desired frame rate of the TV according to the frame rate of the video signal, there are always periodic micro-
jerk images (more often or less often depending on the frequency of out-of-frame frames). When watching TV, it can be seen on the running line, in news channels, with the system auto frame replay this band goes perfectly smoothly, smoothly as the current water of the river "
Hi guys,
I have a Beelink Standard GT1/16G with the S/N FX17N6KG0163, Android 6.0.1 build GT_113M0. I do not know why I can not find any firmware for FX17xxx product!
I want to upgrade 6.0 to 7.1. Please, could you tell me which is the correct firmware for my box? I prefer stock firmware.
Thanks!
First of all, tillaz87 . thank you for your great work here. I did not know that there were dev work for the GT1 Ultimate hidden in the GT1 section. I've seen a lot of work, especially superceleron 's work for the Alfawise S92 boxes (same hardware spec as GT1 regular version I think), but the GT1 ultimate seems not get much love.
A further question, so this is an upgrade/patch works on top of the stock firmware, am I right? And for the first time ever, I saw the 3D game problem reported by other users (tried Lego Jurassic), and it was a black screen. Does the most recent ver of this ROM fix that problem? Thanks in advance.
Originally posted by GentDiors View PostFirst of all, tillaz87 . thank you for your great work here. I did not know that there were dev work for the GT1 Ultimate hidden in the GT1 section. I've seen a lot of work, especially superceleron 's work for the Alfawise S92 boxes (same hardware spec as GT1 regular version I think), but the GT1 ultimate seems not get much love.
Even seen talk of just faulty hardware.
I have no idea as don't have that hardware varient
Originally posted by tillaz87 View Post
You must have the AX version which is a bit of a mystery.. I see people say 3D works with it, others saying not.
I have the G912 (9937) variant of GT1 ultimate updated to 707N0 stock firmware maybe a week ago. I could not confirm if the 3d problem was there prior to this firmware as I did not load any 3D game before, did the test since I saw people mention it. Main beef I had about this box was the BT stuttering issue starting from the beginning ( even with the MM fw build the box was shipped with). I had to use a bt transmitter paired with my bt headset which kinda beats the idea of having a built-in bt chip in the box.
this patch wont ever change hardware related stuff. have you tried games directly from the market? they should work.
if side loading games make sure your using data cache (obb) for mali GPU. adreno, SFX, Tegra would cause black screen.
There are currently 2702 users online. 0 members and 2702 guests.
