[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
fixed that Flash3.zip
if you have a button on that remote you don't use and it has a scancode I could change it to the power button
Here is an example with the esc button on the back of the remote Flash4.zip (hold for power menu)
Ok. Great news. Through the terminal app I looked into the logcat and it founds an error on the kl file, something about Expected key code label, got 'SETTING_MENU' that function probably isn't implemented in this box so I guess I'll try to remove it. What do you think? And I'm really sry about wasting your time.
Originally posted by SocksKodi View Post
Yea the problem is that when the box is turned off or in sleep mode the remote doesn't turn it back on because it needs to be IR
Maybe find the stock rom the remote ships with and see if the config file is diff to the one you were gave ?
There was some weird errors with something like "meson-remote c8100580" and I found this link so I think this might have something to do with it. And btw when I removed the remote files everything was the same but the shutdown menu. It was the same color of the setting menu instead of the normal white. That's all I found out.
Originally posted by tillaz87 View PostChangeLog V8:- Back to full beelink base 705/707ON
- Performance tweaks (RAM,CPU,IO)
- Improved media playback + av sync enabled ~> fixed lip sync?
- Added recovery to power menu (root not needed)
- Added keylayout for H1 remote
- Added screen record from lineageOS
- Removed Youtube ads + others hopefully
- Fixed shortcut buttons on beelink remote
- Fixed action bar bug + more settings bug
- Used installApks.sh to add init.d support
- More framework config changes for ATV
- Prop removed that might falsely identify as rooted (when unroot)
- OpenGLRenderer (libhwui) Properties
- Improved Install script (faster, less extracting)
- Possibly more.. been many changes to stock
- Don't update YouTube its full of bugs.. makes leanback lag! (Wait for Google to fix it or brake more)
- You tell me ???
^^ Sorry, All future updates wont need wipe.. Done lots of testing and comparing that made up my mind to stick with beelink based ^^
Things will probably slow down with me now. unless something big pops up and is of benefit... See first post for links.
-quick question: sorry i know its not ROM related but what media center do you recommend for AFTV because SMPC and FTMC keeps crashing?
Can anyone tell me what a stock version is?
I downloaded and installed an update to go to 7.1.2 back in late October and I have had issues since but works for the most part. How does this upgrade improve the glitches I am now having?
Some apps don't let me use the mouse like speed test app for example. I am rooted and I downloaded another update that doesn't seem to have changed a thing. Still have apps that don't open up full screen either. That's an issue. I am afraid of bricking the box so anyone who can help me please do so. I would appreciate it.
Sent from my iPhone using Tapatalk Pro
Originally posted by Guus View PostHi Tillaz this rom if flashed over V6 will erase all my kodi config and installed applications?
You can just flash the zip over v6 to keep data, for best results wipe "dalvik cache"
There are currently 4142 users online. 0 members and 4142 guests.
