[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
Originally posted by Samekas View Post
I know how to turn it on, that wasn't my question. It will never be smooth and 24p fell because the source movie it's 24 fps are you are outputting at 60hz which doesn't match the original movie fps which is meant to. Blu Ray players do this on movies, they automatically switch to 24p mode.
Maybe Samsung has smarter TVs or something, because I too have a Samsung, and notice 24 fps playback is being sent as 24 fps. Though my tv up converts internal to the DLP chip itself. So all sources, no matter which frame rate, will be in 60fps. Even though it's detects 24 fps and above.
Originally posted by X92-2GB View Post
I have yet to figure out why peeps want auto frame rate... i set all my devices to playback at the source material frame rate.
That is called motion flow aka true motion flow and other brands own names, no Blu Ray player output at 24hz, my TV has direct 24p. Please don't talk what you don't know about, and some TV shows are filmed in 50 fps and 30 .
If by chance the tv show is 30 fps or 60fps, it does not mean the video being sent into your box is true to the source. The provider of the content may have up converted or down converted from its source, which may be 3rd party or network.
going back to the Blu Ray player setting. Yes i set mine to 24 fps for Blu Ray and back to standard for DVD, it's not automatic but it works, though Blu Ray does play back well when left alone.
Let's see here... there are picture settings that effect image, don't know if your tv has Just Scan as a picture option, but it does properly detect image attributes and sets the display to reproduce what it sees, not what it's told by a setting. Let's say your picture option is set at 16:9 wide screen, it will force that but, will not properly reproduce the image as it may have attributes for over scan.
There are more features like that, and play into why some see distortion, ghosting, fuzzy picture under various frame rate and high speed imagery.
Motion flow, WTF! No I said DLP TV. It's internal architecture can only produce an image at 60fps, no matter what you give it. I stated that as there are many types of TVs that have architecture that cannot reproduce 24 fps without reprocessing to its internal native abilities.
So far no commercial TV can truly reproduce a 24 fps image without reprocessing. Some TVs have the ability in the user setting to turn off some of the features but not all, until you run a video calibration utility like DVE you will understand perfect picture features in your settings are detrimental to 24 fps playback. Thus the need to go into the service menu and disable or set preset settings to allow the best video reproduction.
When I said maybe Samsung TVs have better abilities, i stated it loosely, meaning that the processing power is less over done, which make viewing more presentable and more accurate to the source with defaults without calibration changes being needed.
Originally posted by danxc View Post
I have Beelink GT1 2G / 16G QCA9377 and I put firmware UGOOS v.2.0.6 plus SPMC. For me and the winning pair for auto frame rate because it is included in kernel.It does not work in Beelink 2 / 32G
Hello
which remote control do you use?
would like to use all functions with the vorke h1
Thanks, framerate swtich doesn't work on this rom, so amcodeq can decode all video formats? Why are the mediacodeq activated by default if the amcodeq is enabled. How does spmc uses the codeq if all of 3 are enabled?
1. first you need to change permission /sys/class/display/mode to 666 this needs to be done everytime when you restart/power off and use https://github.com/jeff2900/Kodi.AmL...tcher/releases addon
2. download and install https://play.google.com/store/apps/d...jcts.amltester you can turn on auto frame rate there
3. download and install this patch and it adds auto frame rate modes in android settings
i have no idea if ugoos framerate switch features are different than this one may better who knowsAttached Files
Originally posted by kole View Postthank's
do you have the file remonte.conf?Attached Files
Originally posted by JoseM View Post
there are 3 options at the moment
update: for mi box,it needs to be rooted and I don't wanna mess with custom fimware with it so I guess no.Last edited by Samekas; 30 March 2018, 19:33.
There are currently 1931 users online. 2 members and 1929 guests.
