[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by bodays View Post
No I don't... To be honest with you I don't know what it isbut I learn quick
NOTA: The wired thing is that I'm even to using youtube... right after flashing, at the first boot : "Youtube crashed!"
again, and again... sometimes the message si changing by saying "Youtube is carshing continuously"
For the moment, I have deactivate youtube.
Originally posted by tillaz87 View Post
what options did you use in burn tool?
Sorry to bother you tillaz87, but based your previous question, maybe you have an idea of something.....You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by bodays; 30 March 2018, 00:13.
Originally posted by JoseM View Post
for youtube try https://github.com/TeamNewPipe/NewPipe/releases
I will give a try anyway
On the older version of z6 firmware it worked in YouTube and kodi, with latest firmware (which was just the kernel that changed)
it broke auto frame switch completely at least in my testing..
also since the the amcodec fix (libamcodec.so added to public.libraries.txt) people have reported amcodec working with kodi.
Like said though I already ported the settings from Ugoos AM3 2.0.5 for auto frame switching but the rest appears to be in the kernel so not looking good for porting the restAttached Files
i think they use this auto frame rate patch in older firmware version please check it
in ugos settings that I ported they turn this on and off
persist.sys.afr_media_codec=1
persist.sys.afr_media_codec=0
sets this file to 1 or 0 so this works now
/sys/module/di/parameters/nr2_en
and this which I think is same as above
persist.sys.noise_reduction=1
persist.sys.noise_reduction=0
lastly I need to look and compair ugos droidlogic.jar
com/droidlogic/app/PlayBackManager.smali
tillaz87 I installed v10.5 and experience some malfunction. I have turned off CEC fully. But whenever I'm turning my old Panasonic TV off with its physical power-off button, the online radio I'm listening turns off as well. WHen I turn back the TV radio sound comes back (Kodi and TuneIn too). Do you think that even when CEC is turned off it still somehow communicates the turning off to the box?
Originally posted by Samekas View Post
So should I let enabled amcodeq and disable mediacodeq and mediacodeq surface? I have atm all 3 enabled.
In the program settings, it is not necessary to enable "Adjust display frequency according to video" if you already have the system's automatic framerate.
Originally posted by tenoce View Posttillaz87 I installed v10.5 and experience some malfunction. I have turned off CEC fully. But whenever I'm turning my old Panasonic TV off with its physical power-off button, the online radio I'm listening turns off as well. WHen I turn back the TV radio sound comes back (Kodi and TuneIn too). Do you think that even when CEC is turned off it still somehow communicates the turning off to the box?
In my tv settings it's called 'anyconect" I think
10.6 has new CEC settings maybe they work better
The kernel has stuff broke in 10.5 as its in sync with latest z6 firmware. I plan to roll back to the kernel 10.4 uses for now.
Originally posted by danxc View Post
Yes, in SPMC- Settings> Video> Acceleration, leave only amcodec enabled. Include Accelerate for all formats - "Always".
Frame switch is not needed on all tv from what i can see on my tv and what the other user said
Infact when I turn it on with ugos firmware it messes play back up badly
I've tested multiple fps variations on my tv and its all smooth on Kodi
I geuss if video is not juddery on your tv don't worry about it.
to turn amcodec on in Kodi go to- Settings
- Player settings
- Go to bottom and change basic to expert
- now under processing you have MediaCodec options
There are currently 2043 users online. 0 members and 2043 guests.
