[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by danxc View Post
    You can implement this? Would be great.
    Amazing, with UGOOS AM3 2.0.6 automatic framerate switch/automatic resolution switch is working properly with Kodi on my Beelink GT1 2GB.
    Tillaz87 can you add this to your android tv rom? Playback options from 10.5 are buggy and doesn't work
    How it works: when i play 4K HDR movie 23.976fps my tv switch to 3840x2140 23.976, whenn i start fullhd movie its change to 1920x1080 23.976 (depends of movie fps)
      Hello
      Please, I want to update your rom. How can I do? Thanks
        Originally posted by tillaz87 View Post
        Can you enter the pin with tv remote?
        Same result if I enter the pin with original remote.
        thanks
          Originally posted by tenoce View Post
          Would it be possible to put back the power off settings where I could set what the device does when I press the off button (sleep, turn off or stand by)?
          Already back mate in 10.5
            thanks
            this is odd what if you just don't add a code? (press back or something) Your keyboard must be paired at the start as it lets you enter the code with it
            Also are you now using 10.5 from other day?
              Is it possible to update without loose app? With boot card maker it clean all... Thanks
                Not yet, next update will be ota via twrp
                  OK thanks so I can wait for next uptade or I have to install 10.5 and the next update after? Thanks
                    Recant Changes: v10.5
                    • Lower CPU temps
                    • Lower power draw when inactive
                    • AP6255 support?
                    • Missing settings restored
                    • Hosts restored (if want to block ads use this)
                    • MINIX NEO A2 & Lite keylayouts added
                    • Some performance tweaks
                    • New wallpaper (flash StockWallPatch.zip for stock)
                    • Gapps updated
                    Hi, the link for the StockWallPatch.zip is not working for me
                    thx
                      About hosts restored... i am confused about adaway being needed. As long as the build uses a hosts file, i assume replacing it with a custom hosts file should do what I need.
                        Awesome! Haven't tried it yet.
                          it was restored to stock because it was stopping some apps working.
                          Adaway is just recommended because its the easiest way for anyone to block adds and is user friendly, (turn off/on, keep updated, white list etc.)
                            thx
                            fixed
                              fixed
                              all good now
                                Well i use a custom hosts file with SManager to manually run scripts to enable or disable the hosts file. Since I don't allow SManager to run in background, it's a two step process. Though for further ad blocking, i use exposed with ad blocker reborn. It's pretty robust and goes deep into the app structure and blocks various calls as well as black and white listing and allows system apps to be included.
                                I purposefully stopped updating BBC America since last year. It had updated the streaming services to include google ads. Nothing else was changed in app function. As we all know, all NBC Universal apps have google ads included with akami, so no way to block without some app hacking. Since I watch mostly UK streaming apps, all of the major providers apps are ad free using my hosts. Yep, the UK don't play Google so no google ads for you!
                                Here is my current hosts file... The 1st 5 pages are mostly my additions to block unwanted sites and ads. Some issues like downloading files may come up with a permissions fault, which can be relieved by renaming the hosts file to hosts.old, and retry the download. Some captcha issues but not a lot just have to relise the host file is not perfect. Still needs some tweaking.
                                You'll need a good editor to change any entries. It's way too big for solid explorers editor. Remember it must be converted to ASCII text if testing on windows. Android and windows don't use the same text format.
