[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by tillaz87 View Post
TVsettings is the settings on home screen, tablet/phone settings is under "more settings" inside of TVsettings
Not sure if this has been reported. I used this rom on my T95Z plus and it works well. In ATV mode, spotify works properly. Once I apply the NOATV patch, install spotify form the play store, spotify app no longer works. Says I am not connected to the internet. Same condition if on WIFI and Cable ethernet. Any thoguhts, Ynot...
Originally posted by ynot123 View PostNot sure if this has been reported. I used this rom on my T95Z plus and it works well. In ATV mode, spotify works properly. Once I apply the NOATV patch, install spotify form the play store, spotify app no longer works. Says I am not connected to the internet. Same condition if on WIFI and Cable ethernet. Any thoguhts, Ynot...
system/etc/hosts
tried after reboot?
will need logcatAttached Files
Originally posted by ramblefish View Post
I couldn't get a screencast, so i just filmed with a cellphone. Quality is poor and the os is in portuguese, but i believe it shows well the issue:
did you use the "caps" key while trying to type the pin code?
then try NOT to use this key and simply type the pin code without caps or caps lock activated like on a qwerty keyboard. sometimes it works...
Hello .. I'm having a problem with the beelink gt1 ... It happens that it hangs, no reaction when I press the return key or parameter whatsoever with the original remote control or the vorke h1 .. The solution is to unplug the power to restart it .... Is there a solution or it comes from the latest firmware .. Thank you
Originally posted by kole View PostHello .. I'm having a problem with the beelink gt1 ... It happens that it hangs, no reaction when I press the return key or parameter whatsoever with the original remote control or the vorke h1 .. The solution is to unplug the power to restart it .... Is there a solution or it comes from the latest firmware .. Thank you
There are currently 1994 users online. 0 members and 1994 guests.
