your RAM also looks normal.
[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hey tillaz. Just want to say thank you for everything.
After a long time everything is working perfectly.
To finish my configuration do you have any last reccomendations?
.To reduce buffering
.Some weird settings
.Apps you use
.SPMC or Kodi settings I don't know about
If you have the time to answer!
I have the same box as you so I just want to have it perfect.
Originally posted by SocksKodi View PostHey tillaz. Just want to say thank you for everything.
.Apps you use
Since I work so much from PC that its what I do everything on really.. My bookmark bar follows me around ha.
Everything I ever used on kodi was a buffer-fest or just stopped working, to much hassle / upkeep
Originally posted by tillaz87 View Post
Not sure, it works with mine (H1 with code learned) does everything work with the custom remote when its on?
Can you download terminal app and enter "free" and tell me your total ? also is your S/N 706D ?
Originally posted by minixfreak View Postyou have to use spmc .... as regular kodi doesnt have support for amcodec.... you have to enable expert mode and go under player settings.... and yes very fast ..... No problems at all .... theres spmc krypton alpha 2 which works amazing ... i have 4k tv and when i play 4k movies not a single lag or anything colours are good ....
There are currently 1845 users online. 1 members and 1844 guests.
