[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Originally posted by Roman8d5 View PostGood afternoon, tell me how to remove the Power button, I do not need it
Originally posted by craser View Posthdmi 2.0, I connected my box to the TV of my parents samsung 6 series 49 inches 4k hdr plus. I had to disable the HDR function of the box because it gave the purple icons. now it is much better. can it be any problem in hdr? what do you recommend Kodi, spmc or Ftmc?
Picture / Expert Settings / HDMI UHD COLOR
turn it on for all ports or on the box just change it to RGB 8bit or any other lower options
Originally posted by ojerez View PostIt has already happened to me the last 2 times that I turn off the GT1 Ultimate and it stays there in shutting down but it is not finished off. I have to remove the cable. Any solutionLast edited by tillaz87; 24 January 2018, 18:18.
Originally posted by Wbaldassini View PostOlá. Boa tarde ! Tem como vcs me passa o firmware 6.0Â*marshmallow para mim testar ? Mas fazendo ela pelo sdcard?
How To Install:
First make sure your are already running stock 7.1.2 The Official Burn images to update are below, WiFi chip only matters standard or ultimate.
QCA9377 WiFi or AP6255 WiFi or S/N A706D
WARNING: IF ONV7 YOU MUST RE-FLASH STOCK 7.1.2 FIRST !!! ALL OTHERS ARE FINE !!!- Download the 3 files from the archive below and copy them to the root of Internal Storage (Outside of all folders) Not Micro SDcard!
- Install the terminal.apk or download one from the market
- Open the terminal app and type the commands below pressing enter after each
Hi tilliaz !
your rom looks amazing but i have just a dumb question, certainly a dummy one but i didnt find the answer yet.
HOW THE HECK DO I COPY THE FILES IN THE / DIRECTORY ????
shortly, what tool should i use to put those files in the / as i m told ( with ES explorer for instance) that it is read only and i cant change anything in it...
it s an AX12 ultimate box with the 706N rom, and i cant figure how to copy it.
so for all newbies in here, could you lend me a hand ?
thx in advance !
Fred (from france)
thx in advance !
Fred (from france)
There are currently 1775 users online. 1 members and 1774 guests.
