[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
    Originally posted by met67 View Post
    Is it possible to install V9 over V8?
    Yes
    Originally posted by manvel View Post
    So can we install v9 over z6 fw rom installed on GT1 ultimate, or we should wait another patch especially for z6 firmware rom?
    As I remember z6 rom was always 32 bit, isn't it?
    no, its 32bt and has diff framework. this pach would bootloop it.
    The z6 rom is a full burn image so I have done more with it.. patches for beelink base would require multiple versions uploaded which I'm not going to do..
    Plus because of 64 bit it's bigger system partition and effects the resize, I also have it running more fluid than this with boot.img changes.
    I honestly can't see any advantage with 64bit in my real life usage (on this box). I will be focusing on z6 burn image from now as I plan to use it.
    Originally posted by tenoce View Post
    I did exactly as written, but no success. I rebooted after flashing Magisk and then booted to recovery and flashed the module, but without success.
    Strange, I flashed from scratch again and tested this again and its still working for me.
    Did you reflash stock 707 first? Then v9?
    what WiFi are you?
    this is another reason why I favor z6.. 1 boot.img & clean install
    Originally posted by steja View Post
    Thanks!
    So Magisk is BETTER to use than SuperSU.
    SafetyNet is just for pre-install? there is no real protection?
    If you don't use xposed framework and need root hidden from apps & safetynet pass to work then I would say yes it's better.
    But I use xposed for "obb on sd" as I have 128gb Sdcard so if I used magisk it would be more hassle as I understand it. so I have just stuck with superSU for now.
    Originally posted by ojerez View Post
    I thought that v9 was going to be an independent rom instead of a patch. And that there was going to be 1 version for each type of WIFI
    That's the z6 rom which will be released next and mainly focused on. Until beelink update base firmware or 8.0 image appears from an amlogic device
      So the steps are:
      1. Enter Recovery and flash clean 707N0 (Wipe: Cache, Davlik/Cache, System, Data).
      2. Flash Magisk - Restart (to Recovery, again).
      3. Flash SafetyNet fix.
      4. Flash v9.
      5. Wipe Cache, Davlik/Cache.
      6. Enjoy!
      Am I right?
      Flash 707 with burn tool
      flash v9 with script
      Reboot recovery and flash magisk, reboot system..
      Reboot to recovery and flash sfteynet
        Everything works fine v9 and Magisk installed successfully without any issues I'm wondered whether there is any chance to run Netflix TV, I've checked and SatetyNet pass, additionally I'be changed SELinux mode to Enforced, hide magisk for Netflix and Google framework and still get error ui-800-3. Is there any way to launch it on Beelink GT1 Ultimate? Anyone succeeded with it?
          what WiFi are you?
          Yes I did it like that. I have 9377.
          When will you release z6 patch?
            Netflix TV needs widevine L1 DRM it wont work on this box
              I have 6255, 9377 must have something extra that the script has missed or its the boot.img I've not looked in a while.
              z6 is a full image, within a week probably its mainly done.
                No hurry! Take your time. I was just wondering.
                  Z6 firmware is the stock firmware from Vorke Z6, which is compatible with GT1 and has different apps and solutions on board.
                  You cannot update the superceleron rom with this patch.
                  It patches the stock Android 7.1.2 to ATV. First you have to install the stock ROM for your WIFI chip, and then the patch itself is independent of your WIFI chip as the driver for it has been already installed with the stock ROM. The patch does not alter that part of the rom.
                  Is it necessary to put the 705DO and then the 707DO, or directly I put the 707? With what method should I put the original rom without risk to briqueo?
                    You can update directly to 707. I used USB Burning Tool 2.0.9. Never bricked with it.
                      With the official 7.1.2, Netflix work. Not in HD, but yes in SD
                        I'm using TerrariumTV apk instead.
                          Does the V9 fixes the 3D benchmark or 3D games issues ?
                            plug usb on side and power at same time
                            I have reflash image "GT1_707N0_AP6255.img". However, I get now just a green screen when I turn the GT1 on. Then, I flashed "GT1_109M0_AP6255.img" and it worked but it is android 6.0. What should I do next?
                              if you follow the instructions properly it works. did you flash stock burn image first? then v9?
                              perfect and working !!! I waited for this moment to see if the magisk hide worked ... but nothing ... tim vision and others do not go..many libraries drm google..ora I know I ask too much @ tillaz87..but you can integrate in the rom the libraries that google has released for Oreo 8 is to adapt them to v9? otherwise you have to wait until the new ROM comes out
                                ChangeLog V9:
                                Merry Christmas Everyone. Thanks tillaz87 for all the hard work.
