[ROM] Android TV (7.1.2) Beelink GT1 (Multi 6255 & 9377 Standard+Ultimate)
Hi and thank you for your work Tillaz87. I have problem with my new Beelink GT1 Ultimate s/n:A706DSCG20162, after flashed stock firmware with burning tool the screen of tv is green and nothing happend. I try both .GT1_707N0_LTM8830.img and GT1_707N0_AP6255.img and burning tool reach 100% in both cases. Do you suggest me another stock image to try or another solution.
Originally posted by Clayman_32 View PostHi and thank you for your work Tillaz87. I have problem with my new Beelink GT1 Ultimate s/n:A706DSCG20162, after flashed stock firmware with burning tool the screen of tv is green and nothing happend. I try both .GT1_707N0_LTM8830.img and GT1_707N0_AP6255.img and burning tool reach 100% in both cases. Do you suggest me another stock image to try or another solution.
Originally posted by hrrmarques View PostCongratulations for the good work... I found a small bug, arena4viewer apk does not work, it detects an ads blocker. how to fix this ?? Thank you
or if you want ads just delete system/etc/hosts this will require root though so might as well just do magisk thing.
Originally posted by tillaz87 View Post
Install magisk and in its settings enable system-less hosts
You need to use stock 707 firmware for 706D I will add to first post in few mins
You probably also I need to use stock 707 firmware for 706D I will add to first post in few mins
Originally posted by Mathieu73460 View PostThx for your fast answer !
If I want to go back on android 707D0 (not TV) , I can do it with my SDcard and the beelink files ?
Originally posted by craser View PostWiFi chip QCA9377 is ultimate?? after the installed patch ,you need to wap cache?
no wipe. its done automatic if first install
There are currently 2811 users online. 0 members and 2811 guests.
