[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
Originally posted by smasher View Post
ya like i said, its this one and i also have flashed many boxes even have my shield loaded with custom os.. just this device for this flash for some reason cant log in... i have check and done everything i can but a factory reset cause don't wanna sit and load everything back on... but like i said i can use other store apks to get apps but for legit stuff playstore update is faster then having to fish for apk or wait for a 3rd party store to do it
Hi ,
strange thing , if you not want to Factoryreset or flash new , i think
u must live with it , maybe it helps to wipe full App cache & Davik
cache & reboot , wait till ready & try again ,
i always use Clear Cache from SpecSoft from Store , but others
will have it too , nice simple App , to clear both ,
good luck / gefattern
Originally posted by michael2t View PostHello SC,
Any news on the Dual Wifi Build of Android 7.1.2 scv1?scv2 ?
Wishing it was ready ...
I am using SCV1 and there seems to be a bug when I stream Iheart radio it always stops every 5-8 minutes ...
Very strange which .so file can I change that would effect base audio streaming ... Playing local works great
Just stream audio only through normal player no mxplayer no kodi ...
thanks in advance
Michael T.
Did You figure any thing out about the Iheart streaming Issue ... ???
thanks in advance
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Originally posted by sesdave View PostIs there any firmware for this box that will allow me to select 4k screen resolution. Highest displayed in settings on latest is 1920*1080@60.
Guest
Originally posted by superceleron View PostHi guys/girls, sorry for the lack of updates, but really dont have to much free time this days to do my custom rom work, if anything changes i will update my roms if not...
Thanks for all your roms over the years. Hope you can update this one to sort out no 4K resolution option sometime in the future. I can but hopeUpdate - as 1 of my boxes kept freezing after a few weeks with 180713 firmware I though I would install this one just to see what it was like. Big suprise = it gives me 4K options in display resolution settings so I will run with this until my boxes freezes again. I think its a bad one - 3 others run great. I should have tried it when it first came out but the fact a few people were reporting resolution issues with their TVs put me off. So as always big(albeit very late) thanks for this rom.
Hi
I tried to use FTMC (is the only player that plays my Video Files flawless thanks Superceleron) as external in Kodi 17.6(better Skins) by
playercorefactory.xml
<playercorefactory>
<players>
<player name="FTMC" type="ExternalPlayer" audio="false" video="true">
<filename>org.xbmc.ftmc</filename>
<hidexbmc>true</hidexbmc>
<playcountminimumtime>120</playcountminimumtime>
</player>
</players>
<rules action="prepend">
<rule protocols="smb" player=FTMC />
<rule dvdimage="true" player=FTMC />
<rule protocols="rtmp" player=FTMC />
<rule protocols="rtsp" player=FTMC />
<rule protocols="sop" player=FTMC />
<rule internetstream="true" player=FTMC />
<rule video="true" player=FTMC />
</rules>
</playercorefactory>
but its not working
maybe someone can help.
I believe 1920*1080@60 is the default.
If you are using SuperCeleron's ROM SCV1-BETA, You can change the resolution:
To CHANGE this you have to go into SETUP (looks like a GEAR on main screen of launcher),
then Select DISPLAY...
then Select HDMI ....
Now, Select RESOLUTION ..........There you will see a list of resolutions, including MANY various 4K resolutions.
NOW, Select "3840x2160p60" resolution (works for many 4K TV's).
Hi ,
so if , latest Rom of Superceleron is installed , and you exactly
followed the Instructions of the Developer , then all must be
good , are there others Users with same Problem ???
I recently re-flashed SCV1 and I am having same problem - I can not log into Google to setup account, Green SIGNIN Button does nothing.
There are currently 2604 users online. 0 members and 2604 guests.
