[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
Originally posted by Wyle View Post
How did you make the ROM if you didn't have a RK3399 box to test it on?
You are funny.!! SC does NOT have a h96 max with the QCA9377 wifi chip only one with the AP6255 thus has no source code and
no unit to test a qca9377 build on ....
Reading is fundamental ((((SMILES))))
And Now you know ....
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
Originally posted by michael2t View Post
Hello Wyle,
Michael T.
i think he means his Amilogic S912 H96Pro+ with SCV7a , this Box uses Wifichip QCA9377 .
Would be nice if there comes more RK3399 support in Future , want to buy the X99 , looks
interesting .
greetings / gefattern
Hello Wyle,
Michael T.
I think you are all confused... I was questioning SC's comment "well maybe i will get one" - where He states he doesn't have a (RK3399) box.
So I asked, "How are you able to write a program for this box if you don't already have one?".
All of you got stuck on the idea of the WiFi chip.... (6255 , 9377, etc.)
BTW -
SC, What if you could release a nightly build ROM for just Ethernet users - those like me who use their boxes wired through Ethernet and don't use WIFI?
When I was experimenting with my old ALFAWISE H96 PRO +... I was able to successfully burn and run your ROM for the other boxes. I never used WIFI so I never saw a difference with a ROM for different AndroidTV BOX. I suspect RK3399 boxes are so similar, that a ROM for one TV Box will work on another for a guy like me. (WIRED ETHERNET) - Or am I wrong?
Originally posted by superceleron View PostMany thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog V1:- Based on stock/and another rom....
- General optimization, should be smoother and faster!
- FIxed Stream apps 4k webm/vp9 playback (youtube etc..)
- Some house clean!
- Mem usage lot better now.
- Boot a lot faster, emmc also faster!
- 1080p Ui
- Youtube 4K support (no youtube leanback, if i did that one you will lose access to some apps in the playstore)
- Added power button to navigation bar, single press = poweroff, long press power menu.
- Added Status/Navigation bar auto hide, so dont show anymore on Youtube and other apps!
- Added a setup wizard.
- Organized some boot scripts.
- Added lots of kl's.
- Netflix, youtube, playstore...etc... fully working.
- Many Gamepads supported.
- Playstore updated (GMS is updated the 1º time you login to the store)
- Lots Permissions fixed.
- FTMC Build 30 RKversion (the best player for this device)
- Fixed RKcodec Playback and fractional HDMI in FTMC. (Fractional HDMI Only works in the 3328 and 3399)
- Added a few apps...
- Updated some codecs
- Fixed Bluetooth problems.
- Updated wireless driver.
- Added SC modded WeOS launcher (menu button on the remote is your friend in this launcher)
- And some other little tweaks and fixes...
Tweaks V1 Enable Backdrop Screen Saver:- 1. Settings -> Screen Saver
- 2. Inside press "Screen saver" and chose "Backdrop"
- 3. After that go back and in "When to start" choose the time that you want the screen saver to kick in!
- 4. Dont touch "Put device to sleep".
- If you guys want to try it press "Start now"
Bugs V1:- If you get 848x800 resolution, sorry cant help you... its a bug in the kernel that cant read the EDID from some TV's...
- Don't try Magisk, it wont work!
- The rom is rooted with supersu 2.82 BUT NO supersu app due to some Incompatibilities, and if you add it DONT UPDATE SU BINARY YOU WILL GET A BOOT LOOP!
- Suspend in Power Menu dont work, it powers off the box, but since the boot is so fast in this box i really dont think is a problem!
- I bet a lot more Bugs...
Want to buy me a beer?
Download:- DOWNLOAD HERE SCV1-Beta 7.1.2 for the Alfawise H96 Max
- MD5: 467F2725F33A542D8041AA576BBA1EAD
Install instructions:- Search the forum for instructions, is the same as all other rk boxes...
- This box if you want to use a external USB HDD powered by the box you need at least a 3A PSU.
Where to buy:
1º BOOT MAY TAKE AROUND 5 MINUTES MAYBE LESS!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
Is init.d enabled on this build ??
thanks in advance
RE: NETFLIX 1080p & 4K support
SuperCeleron, Have you seen this Webpage? :https://androidpctv.com/new-firmware-zidoo-h6-pro-with-support-for-netflix-hd-v1-0-10-beta/"
or this one:
"https://forum.xda-developers.com/android/apps-games/app-netflix-hd-widevine-drm-l1-devices-t3307241"
or this one from Zidoo:
"https://androidpctv.com/new-firmware-zidoo-h6-pro-with-support-for-netflix-hd-v1-0-10-beta/"
The first 2 links claim to have gotten a lowly S905 box with Widevine L3 support to play NETFLIX in 1080p or Better simply by copying the WIDEVINE Libraries to their boxes.
The 3rd link is software for a ZIDOO box that claims to run Netflix as 1080p through firmware.
I thought you could read his postings and see if they solved the "NETFLIX not playing in HD" issue...Perhaps if someone has, you could port it to your code and bring us Netflix in 1080p or even 4K!Last edited by Wyle; 05 April 2018, 05:43.
Originally posted by Wyle View PostI think you are all confused... I was questioning SC's comment "well maybe i will get one" - where He states he doesn't have a (RK3399) box.
BTW -
only Roms for same Socs can run , if not too many difference in Specs , a Amilogic Rom can not work on a RK Box .
Hi ,
Originally posted by barto41 View PostHi guys, install this ROM on my H96 MAX 4GB Chip wiFI 6255
Everything perfect but the wifi does not work
My question is: I have a firmware copy of my h96 (extracted with FW_TOOL)
but is it unpacked as I can reinstall my fimware ???
Or install my firmware kernel
THANK YOU
Your rom is perfect but you need wifi, reinstall the original firmware and ready
I hope you prepare a rom that works wifi
You know a lot and we trust you
Thanks guys
Hi superceleron thanks for answering
Thanks guys
what Wifichip does your new H96Max use ???
There are currently 1376 users online. 0 members and 1376 guests.
