[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
Thx SuperCeleron.
I like your h96 pro roms.(912)
But I got no WIFI on my new H96 MAX. (3399)
The WIFI Switch doesnt work, and in the first start configurator it will show no available WIFI networks.
I flashed it with factorytools, first as upgrade, and a second time as restore.
both update methodes are working, but no wifi.
Is that normal? Have you an advice for me?
Thanks.
Thanks.
Originally posted by StevenP94 View PostGearbest story: My H96 MAX box was broken in 24 hours, after a month of no-reply mails they offer me a 25% refund... any hints ? Paypal protection ?
This is probably going to sound weird to you all. I have a NVIDIA Shield and a current generation Intel NUC i5 Windows HTPC, both of which are more powerful than the H96 Max. But, I bought it anyway. The reason I bought it is that I wanted an Android solution, which I couldn't get going on the NUC, and I very much dislike the Android TV OS vs full Android on the Shield. This seemed like the most powerful/best option below the Shield. I didn't come across this post until after I bought. I am still waiting for it to get here. After reading here, I am a little concerned. It sounds like you need to use a special fork of Kodi for good performance. That's disappointing. Is that still true? Even with those using it, there seem to be problems.
Also, on one other note, I bought this one:
https://www.newegg.com/Product/Product.aspx?Item=9SIA29G6A59304&cm_re="h96_max"-_-9SIA29G6A59304-_-Product
I know it can be obtained cheaper. Sadly, for reasons I won't get into, I have to buy from a list of certain sites, and Newegg is one of them. Anyway, it doesn't actually even say the brand. I don't know if it's Alfawise or what. Is that bad? I initially assumed it would be the same performance as other reviews I have read, but after reading here and seeing how some people's comes with Android 7 out of the box, etc., it seems there could be differences from brand to brand.
Originally posted by mystik View PostThis is probably going to sound weird to you all. I have a NVIDIA Shield and a current generation Intel NUC i5 Windows HTPC, both of which are more powerful than the H96 Max. But, I bought it anyway. The reason I bought it is that I wanted an Android solution, which I couldn't get going on the NUC, and I very much dislike the Android TV OS vs full Android on the Shield. This seemed like the most powerful/best option below the Shield. I didn't come across this post until after I bought. I am still waiting for it to get here. After reading here, I am a little concerned. It sounds like you need to use a special fork of Kodi for good performance. That's disappointing. Is that still true? Even with those using it, there seem to be problems.
There are currently 2393 users online. 0 members and 2393 guests.
