[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
    superceleron did you know that the SDK2 (7.1) was released on 12.12.2017 and uploaded on 18.12.2017?
    rk3399-android7-SDK20171212
    best regards,
    DOM
      best regards,
      DOM
      Ye i saw it, no time to mess with it now... maybe in February...
        better late as never :-)
        i wish you a great x-mas.
          Hi. I install this ROM and see some problem:
          1. In some menus in the right upper corner absent icons. For example in "Settings - Apps" no icons.
          2. Cannot grant access to write on SD to app. For example in Ttorrent select folder on SD, app says "Read only, grant access?". I press "Grant" buttion, nothing happens.
          On the Android 6 version all working fine. How repair it?
            So I just purchased this from gearbest the other day and flashed your cfw successfully.
            However I'm having an issue where wifi is disabled... I try and turn it back on but it rejects the action and remains off/disabled.
            Please help thanks!
            • mo123
              mo123 commented
              Editing a comment
              Then your device might have a different wifi chip than the original one or what firmware is made for.
              That is why wifi will turn off if you try to turn it on.
              You have to find out what the wifi chip is in your device and ask Gearbest or look for the original stock firmware to make the wifi work.
              You can then root and run dmesg in a terminal to find your wifi chip name to know what ROM's are compatible.
            @harveyconnor Same Problem here. SuperCeleron answeared that different WIFI chips inside the boxes.
            Try Oktober Stock FW (look into the 3 threats here in the forum, its posted by an user. it was on a sd card, he got with his box.)
            This FW is working very well. Hopefully SuperCeleron will build an SCV2 image with integrated drivers.
              superceleron, Is it possible to make your ROM ddr4 compatible? I have an r99 unit but can't find any firmwares & the stock is poor. Regards
                Because of Wifi loss i was forced to flash a stock rom.
                Version: rk3399_hcy_7.1.2_528_40M_171016.img uploaded from a user in this board. (thanks)
                Now Wifi 2.4 + 5 Ghz is working well.
                Hopefully SuperCeleron will implement the drivers from this Stock rom.
                Have a nice Day
                Friends, hello ....
                I installed the H96 Max 4G Ram, 32 GB Rom device google player storeden supersu.
                My device did not turn on again (stayed in the MBOX post).
                I had to install a new Software.
                But what software I have installed does not work wifi.
                I could not find the rk3399_hcy_7.1.2_528_40M_171016 software that your friend mentioned.
                does this software solve the wifi problem? can you help me find the software ???
                  Hi. Same issue. No wifi.
                  The new wifi chip is the LTM8830.
                    Â*
                    do not you have a solution to this problem?
                    Will we always wait?
                    But the first time I bought my device, it worked wifi.
                    it means there is absolutely no software or plug-in that suits it.
                    please help me.
                    I am in a very difficult situation ....
                      try this: http://freaktab.com/forum/tv-player-support/rockchip-based-tv-players/rk3399-devices/660920-firmware-android-7-1-2-stock-alfawise-h96-max-rk3399-4gb-32gb?p=687210#post687210
                      posting #98
                      this is the oktober stock firmware. it works very well. i got no wifi with scv1. but with the oktober FW wlan is working well. but meanwhile, i decided to drill some holes and now i have LAN cable. without lan cable it was not possible to play 4k movies. now, with the lan cable 4k works well...
                      downloadlink:
                      https://mega.nz/#!ck5TzbiL!3CDvVHLF9...hjw6NDEYOs8j6U
                      i dont remember if the factory tool was inside. i flashed it with factory tool 1.44
                        posting #98
                        downloadlink:
                        Thank you very much.))
                        My problem is solved.
                          Can we reflect the You tube videos on the H96 Max?
                          Mecool k3 pro is also made.
                          LG and Samsung are mirroring on Smart TVs.
                          Can we make projections on H96 Max too?
                            altincayir you want to stream youtube movies to the h96 box? sounds like a bad idea.
                            go to amazon, buy a cheap mini keyboard with backlight illumination and start the youtube app on the h96 or youtube into kodi. thats a great way :-)
                            it is possible to get a lot of apps into the playstore for screenmirroring. :-)
                            cheap, but very good (14-20 Euro some times with discount):
                            highest quality (22-28 Euro):
                            https://www.amazon.de/Rii-Touchpad-M...yboard+rii+i28
                            ATTENTION SELECT YOUR COUNTRY STYLE KEYBOARD... QWERTZ or QWERTY!!
                              Dear friend, hello ...
                              I was wrong.
                              I want to watch it on the H96 Max with the chrome cast feature from the mobile phone, from the android device (mobile phone, tablet) and PC, laptop.
                              Can you help me?
