[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
    Just got my H96 Max with Android 7.1 installed. How does it compare with your ROM?
      What is the version date of the rome installed on the H96 max if you could do a screen cap
      would be great thanks..
        Hope this is the information you request : os version 7.1.2
        • trebor
          trebor commented
          Editing a comment
          Thank you a little dated...but if it's working ok play first....
          Try to get a copy of the installed rom on you box. ask supplier
          Try SC rom, its very good. but alway good to have a copy of the original if you can
        #34
        Hello SC,
        Does this Android 7 version have Samba Client ? Or Will it Be in the NEXT Version ?
        Thanks In advance
        Michael T.
        3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
        CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
        Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
        Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
          Did install your ROM, is nice.
          My problem since purchase however still remains.
          I purchased this box to play the 4K videos I made with my camera, but images remains shaky.
          The files have the following specs : 3840 * 2160 , 61081 kbps.
          Copying to internal disc, using kodi & vlc same problem.
          Does someone have an idea to solve my problem?
            Did you use FTMC? that it goes with the rom? if you dint.. use it!
            You will see the diference to kodi!
              Friends at home I use tv Samsung LE37C530F1W LCD tv, H96 Max device box Android 7.1.2 version. As I pulled out of the box and no playing with the setting I tried, but I couldn't get the sound in any way. HDMI cables with a different cable this experiment I am suspecting did. The result is the same.
              Moreover, it is a different model apparatus LCD TV using HDMİ cable to both. No device problem. ...
              H96 MAX with my taking a different satellite device bring together I came home. I upgraded my tv software and I'm back to factory settings. When I brought with me the other I tried both HDMİ cable satellite device. The result is perfectly normal, no problem.
              H96 MAX is the same problem when I try to tie. Image, but there's no sound again.
                Unfortunately my problem with 4K video remains with FTMC. Can it be the HDMI cable that was delivered with my box, no problem with Full HD video ? I do have sound which is in sync.
                Any other suggestions?
                Thanks.
                  Thanks.
                  I really dont know, i dont have a 4k tv and it will take a long time until a get one... expensive...!
                    Prices have dropped the last 3 years so I got it at the price of a full hd tv, hope this will happen soon in your country too.
                    Did conversion of 4K file and now it plays very well with FTMC. Thank you.
                    Just for info the specs I got with mediainfo:
                    ORIGINAL
                    Format : MPEG-4
                    Format profile : Base Media / Version 2
                    Codec ID : mp42 (mp42/avc1)
                    File size : 122 MiB
                    Duration : 16s 800 ms
                    Overall bit rate mode : Variabel
                    Overall bit rate : 60,8 Mb/s
                    Encoded date : UTC 2017-07-12 12:53:39
                    Tagged date : UTC 2017-07-12 12:53:39
                    Video
                    Format : AVC
                    Format/Info : Advanced Video Codec
                    Format profile : [email protected]
                    Format settings : CABAC / 2 Ref Frames
                    Format settings, CABAC : Ja
                    Format settings, RefFrames : 2 frames
                    Codec ID : avc1
                    Codec ID/Info : Advanced Video Coding
                    Bit rate mode : Variabel
                    Bit rate : 60,5 Mb/s
                    Maximum bit rate : 70,0 Mb/s
                    Width : 3 840 pixels
                    Height : 2 160 pixels
                    Display aspect ratio : 16:9
                    Frame rate mode : Constant
                    Frame rate : 25,000 FPS
                    Color space : YUV
                    Chroma subsampling : 4:2:0
                    Bit depth : 8 bits
                    Scan type : Progressief
                    Bits/(Pixel*Frame) : 0.292
                    Stream size : 121 MiB (99%)
                    Language : Nederlands
                    Color range : Limited
                    Color primaries : BT.709
                    Transfer characteristics : BT.709
                    Matrix coefficients : BT.709
                    Audio
                    Format : AAC
                    Format/Info : Advanced Audio Codec
                    Format profile : LC
                    Codec ID : mp4a-40-2
                    Source duration : 16s 853 ms
                    Bit rate mode : Constant
                    Bit rate : 256 kb/s
                    Channel(s) : 2 kanalen
                    Channel positions : Front: L R
                    Sampling rate : 48,0 kHz
                    Frame rate : 46,875 FPS (1024 SPF)
                    Stream size : 520 KiB (0%)
                    Source stream size : 521 KiB (0%)
                    CONVERTED
                    Format : MPEG-4
                    Codec ID : isom (isom/iso2/mp41)
                    File size : 70,0 MiB
                    Duration : 16s 835 ms
                    Overall bit rate mode : Constant
                    Overall bit rate : 34,9 Mb/s
                    Writing application : Lavf56.40.101
                    Video
                    Format : MPEG-4 Visual
                    Format settings, BVOP : Nee
                    Format settings, QPel : Nee
                    Format settings, GMC : Geen warppoints
                    Format settings, Matrix : Default (H.263)
                    Codec ID : mp4v-20
                    Duration : 16s 440 ms
                    Bit rate : 35,6 Mb/s
                    Color space : YUV
                    Bit depth : 8 bits
                    Bits/(Pixel*Frame) : 0.171
                    Stream size : 69,7 MiB (100%)
                    Writing library : Lavc56.60.100
                    Audio
                    Format : AAC
                    Format profile : LC
                    Bit rate : 128 kb/s
                    Sampling rate : 44,1 kHz
                    Frame rate : 43,066 FPS (1024 SPF)
                    Stream size : 263 KiB (0%)
                    Default : Ja
                    Alternate group : 1
                      ORIGINAL
                      Format : MPEG-4
                      File size : 122 MiB
                      Video
                      Format : AVC
                      Codec ID : avc1
                      Color space : YUV
                      Bit depth : 8 bits
                      Your problem is the highlighted part, only L5.0 or lower works correctly.
                      Video
                      Format : AVC
                      Format profile : High@L5.1
                        Video
                        Format : AVC
                        Â*
                        I took this video with my Panasonic HC-VXF990 which dates from 2016.
                        Is a fix possible?
                        Also have a general problem with this box. I can set the display to 4K, but in every app says Full HD resolution at 60 Hz.
                        Problem with box or Rom ?
                        Thank you.
                          Is a fix possible?
                          Thank you.
                          is how RK does their stuff, they are reporting the UI size that in rk boxes are, they always are or 720p or 1080p even is you set the settings to 4k.
                          Dont worry you still see you videos at 4k since the framebufer uses the the real tv spec and not the fake res!
                          And no its not a bug... is a feature
                          About the video, yes L5.1 have some problems, no fix for now!
                            ORIGINAL
                            Bit depth : 8 bits
                            Is a fix possible?
                            Profile L5.1 heavily loads RK3399 (load CPU up to 99%). You need:
                            - good power supply so that there is no voltage drop;
                            - improve cooling CPU;
                            - optimize OS (disable/remove unnecessary sys. applications);
                            - change RK3399 to Nvidia Shield.
                            CONVERTED
                            Re-encode degrades the image, especially x263.
                            4k is not for this.
                            P.S. x264 10-bit L5.1 plays only in SW (software, with frame skips)
                            can the same thing with x264 8-bit L5.1 [no hardware support (?)]
                            Yundoo Y8 A6 [RK3399]
                              Thank you for the information, strange feature, very confusing for people like me.
