[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
    @altincayir
    i know what you mean. but i dont prefer to stream from mobile phone to the h96.
    what kind of media do you want to stream?
    movies? youtube? that makes absolutely no sense.
    1a.) your mobilephone or what ever drains batterie
    1b.) your phone is not usable for other things, while watching movies from phone...
    2.) the picture quality will be reduced, because of reconverting the original video to a new stream format.
    3.) you get latence, while playing etc.
    4.) 4k only works direct on the h96
    5.) HDR only works direct on the h96 (i dont think its part of some sharing like chrome cast)
    6.) if the h96 is working in wifi mode, you can get stuttering in very high quality mode, or the stream will reduce quality.
    what is the problem to use youtube directly on the box?
    what is the problem to play games directly on the h96?
    what is the problem to watch movies directly in kodi on the h96?
    simply share your hdd drive on your pc, server or nas, and mount it in kodi.
    thats the real mission and normal way with the h96 and any android tv box...
    there are many ways to share laptop, tablet, phones screen to the h96.
    install vnc, anydesk, teamviewer and maybe chromecast server on the h96.
    check the playstore, or search via google.
    good luck my friend. its simple, try google or check some helping movies on youtube. :-)
      Originally posted by DOMin8or View Post
      @altincayir
      it seems to be the picture I want.
      Why is H96 Max missing on the list?
      What do I need to do to have H96 MAX in that publication list?
        Sry to be asking this, but any news about a new version of this rom?
          I'd like to second that request for an Update that includes the fixes in the 1/2/18 firmware
          for whatever reason the stock rk3399_7.1_new_H96max_P_A_E_1.5M648M_ear_180102 will not boot up on my box
          it just hangs at the H96 Max logo
            Mate you need to use the proper tools. Please refer to the other thread on this forum. I had the same issue and it is resolved now
            Sent from my HTC U Ultra using Tapatalk
              what tools ? I have tried FactoryTool_v1.39 and RKBatchTool-v1.8 and the box does not bootup with the new firmware
              I can flash this rom fine with those, so I don't understand what you mean by proper tools
                You need to use the latest versions of the tool. Look at this post
                    that's awesome thanks for point that out. I'll flash again tonight after work.
                    ok well i flashed the new firmware and their are no improvements
                    the box still barely plays 4k content off an sdcard even at 30fps theirs lag
                    The Amazon Prime videos still crash when you try and load a video.
                    this box has been noting but a big disappointment, Only SC Rom's make it even usable
                    I guess I learned the hard way about rockchip
                      Well that's the state here as well. This is my first box. so I don't know if it's something to other rockchip or the manufacturer itself. I thought of buying zidoo, specially for the promised software support on their website.. but I choose this for sheer specs.
                        This is my 3rd Android box .. I can tell you this my T95z Plus was less than half the price of this box and does pretty much everything this box does and some things even better
                        The H96 Pro Plus is the same Am S912 and while not as fast as the rockchip it gets the job done pretty well
                          I see. I can imagine that the software surely plays lot of difference. Would you say that ?
                            Yes I have been lucky and was able to use SC roms on all my boxes... It makes a huge difference
                            I also donate to him every chance I can
                              Hi any chance of an scv2 in the near future. Still a few minor issues with the box but very usable. Just looking for icing on the cake
                              • superceleron
                                superceleron commented
                                Editing a comment
                                Well when i have something new to show i will rls a scv2.
                              I'm hoping it has drivers for both types of wifi module. Otherwise I'm stuck with the stock firmware
                              • superceleron
                                Editing a comment
                                Well that is hard... it needs to be done at dev level(sdk) the support for both!
