[ROM] AlfaWise H96 MAX Android 7.1.2 4Gb/32Gb - SCV1 Beta
Originally posted by JoseM View Post
But dont worry i dont forget you all
Originally posted by isfontes View PostRegarding the 20180502 firmware, they removed the Main Menu Display option (COLOR, which allowed the 10bit ycbcr444 configuration), which dramatically improves the image. Returning to 20180502.
my guess this isn't official stock firmware release just some custom one
btw he means 20180525 firmware not 20180502
Hmm dont look custom to me, i just opened and seems stock, just weird why they did it!
Anyway im not going to use it.. tried on mine seems worse...
20180502 is better!
Guest
Yes i notice it he mean it the 25 one.
20180502 is better!
superceleron
(The rom is rooted with supersu 2.82 BUT NO supersu app due to some Incompatibilities, and if you add it DONT UPDATE SU BINARY YOU WILL GET A BOOT LOOP!)
don't know if this info was posted here before but according to some user to avoid this issue supersu needs to be installed as a system app then su binaries can be updated and no bootloop
question... i flashed this firmware on my box and set up apps and such and now when i go to go to the playstore or even under google settings and log in an account it does nothing green button on playstore just wont do anything, under system settings when i hit add google account just brings me back to the window to select it again
Originally posted by smasher View Postquestion... i flashed this firmware on my box and set up apps and such and now when i go to go to the playstore or even under google settings and log in an account it does nothing green button on playstore just wont do anything, under system settings when i hit add google account just brings me back to the window to select it again
please wipe all Data & Cache from the PlayStore & PS Services
and try to lock in again , good luck / greetings / gefattern
Hi ,
done this not working... i cant add no account from youutbe app/store app/os settings and accounts it wont open the setup window for it
if u have important Data & Apps to backup do this and try a
Factoryreset , maybe Superceleron knows help , what Rom
was installed before , lower Version , did u "eraseFlash" before
flashing Rom ??? , maybe u must flash once more , what green
Button do you mean in Playstore & if you can open the Store
there must be an Account otherwise it will not open , u always
first have to sign in before the Store opens .
Try the Factoryreset after thhis do first the Playstore Account ,
what about Chrome ??? good luck / gefattern
Ps : backup your important Data & Apps before , if needed
Hi ,
just a wierd issue is all i have flashed many boxes and even this one a few times and never had a issue... but ya i can get all my apps and such without the playstore thats fine its just annoying to have to use other apps to update main ones cause store wont let me add an account same with the os it just takes me back to the window before i click sign in or add account.. so i thought maybe someone had a fix for this without having to reflash/factory reset
so if , latest Rom of Superceleron is installed , and you exactly
followed the Instructions of the Developer , then all must be
good , are there others Users with same Problem ???
hope you can get it working ,
There are currently 3359 users online. 0 members and 3359 guests.
