Originally posted by ReaperMan View PostDev:Shonk
Wisdom firmware had little support.
Might be possible to upgrade to android 9... if factory firmware is a total letdown?
. OS - Buildinfos Androld version :7.1.2 Release Codename : REL API LEVEL: 25 CPU ABI: arm64-v88 Manufacturer : Amlogic Bootloader : unknown CPU ABI2: Hardwace: amioglo Radio: unkncwn Board 1 q201 9377 Brand : Amlogie Device: q201.9377 Display : 201.9377-userdebug 7.1.2 NH047L 20171120 taat-keys Fingerprint Amlogic/4201.9377/201.9377.7.1.2/NHO47L/20171120:userdabug/teat-keys Hest: wiedom2-work ID: NHG47L Model : H96 PRO+ Product i 201.9377 Tagn test kays Type: userdebug User : wisdom2 - Battery
- Try looking into Frankenstein 3.1 or 3.6(?) firmware- Android 7
- Consider Android 9 : https://forum.freaktab.com/forum/tv-...d-pie-for-s912
Be informed on how to "Un-brick" your China Box before trying these.
@orshal,
Mecool M8S Pro (DDR4) (Q9377)
Check out the Android Pie Discussion
slimBOXtv 15.1 Changes: • Added support for Bromite SystemWebView (download from the project website) • The AOSP keyboard startup icon is hidden • Replaced Setup Wizard (ATV) • Fixed issue with logging in to Google account • Updated WebView and Google Play service • Added additional Bluetooth settings with the display of the
Originally posted by Maurice980 View Postis there a way to change the system default launcher? Thanks
if you really want to change it easily i recommend you using the "normal" version of this fw, since this one is the ATV.
Use SweenWolf's LAUNCHER MANAGER for AndroidTV app, version 1.0.4 buried halfway down in the first post, just need to activate USB_Debugging in Developer Settings of Android in not already on.
Originally posted by RiCkLaR_atvX View Post
There are currently 3629 users online. 0 members and 3629 guests.
