The only drawback with 8.0 for me, is that I figured out how to make 7.1.2 work perfectly for my needs, along with all the xposed modules I use. I have a funny feeling 8.0 won't play well with my older modules. As I am barely able to use them on 7.1.2, with some selective hand picking of early versions.
Originally posted by superceleron View Postwell it took me 2 days to get it done to this stage... i need to stop now so i can focus on my paid work again :/
well not this build since i cant rls it, is private source...(you see i removed in about picture kernel names... build server i use for work...) and im not going to do their work... when they rls the a stock android 8 rom i will then make a android tv build for it.
About 8.0... well actually mibox is working great with it... and yes it do have some problems, but not the end of the world... since are workable problems, but the main problem is s912 implementation from amlogic that is... a mess... mainly because of kernel instability ( lots of kernel panics... )
Originally posted by superceleron View Postwell not this build since i cant rls it, is private source...(you see i removed in about picture kernel names... build server i use for work...) and im not going to do their work... when they rls the a stock android 8 rom i will then make a android tv build for it.
Thanks for your support with this ATV firmware.
How is the state of the amlogic kernel?
Are there still problems with the hw codec? (e.g. some videos are pixelated blocky, ac3 sound is problematic for hw rendering in some application(e.g. Plex))
blocky playback: it is interesting that Kodi (16) with amcodec doesn't have this pixelation issue.
There is an other custom atv rom I've found which could be compatible with H96Pro+
atvxperience.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf atvxperience.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Is it possible to run a firmware from an USB drive (for testing). Like you can run a Windows 10 from an USB drive.
Originally posted by Lacix View Post
Hi superceleron
About kodi 16 and playback, that is because that kodi 16 used amcodec and that was removed in kodi 17....(you need to ask them why)
That rom dunno i dont know, i never use other ppls roms, only my owns or stock...
Originally posted by Morgan5000 View Post
Do you intend to update our H96 Pro Plus with Oreo ATV? When do you think you share ATV Oreo
But dont get you hopes up for more than A8.0.. because looks like Android 8.0 it will be the last for s905x and s912 chips....
Hi SuperCeleron, I was having issues with one of my H96 boxes so I backed up a working one and restored it to the one which wasn't working properly.
The issue I'm now facing is that they now have the same wireless mac address, however the box is working much better. How can I change the MAC address back please?
I've not rooted the ROM.
I've managed to change the Bluetooth address without an issue so it is simply the Wireless.
I can find the wireless mac address (once booted) in /sys/class/net/wlan0/address but can't replace that without rooting and it's not there if I reboot into recovery.
Thank you,Last edited by Akirainblack; 10 October 2018, 13:35.
[QUOTE=Lacix;n747010]Originally posted by superceleron View Post
Well kernel on what android? if its android 7, pretty good since is a already old kernel....
/QUOTE]
I mean is it the kernel in Android 8 fixed regarding the hw codec? Or the same problems occur?
Really fixed only in 8.1.
Originally posted by tiku View PostCan somebody please kindly tell me which ROM from the first post will work in my H96 Pro Plus 3/32gb, please see the pics of my Box,
Thanks in Advance
green motherboard = scv1 Green pcb = not for your pcb
Update scv4a Work with blue and Green version.
There are currently 1871 users online. 0 members and 1871 guests.
