Originally posted by Rasbi View Post
Originally posted by hcardoso483 View Post
Sorry mate I desagree, unfortunately you don't know what Android TV is, I'll explain, the full play store contains apps for all types of devices, TV, tablet, smartphone, car audio, etc, so this time is optimized for TV,(leanback), so only the apps that are optimized for TV will show, you can still side load them but you will need another way to launch those apps that are not optimized for TV, on the leanback experience you interact with a remote control so the UI is desined for a non touch screen control, the tablet UI is has you are used to see in tablets an phones, this rom is awesome, it's very snappy in time you will get used to it or maybe not should you install the tablet UI based one check that one out, it is very good too. Have fun...
Just replace your TV file permissions with my tablet file permissions, reboot and uninstall play store updates and play services updates. Try and use play store every 2 minutes, until playstore pops up in phone play store, and search for what ever launcher you want from play store. Or down load play store and play services from apkmirror, and manually install, then go to playstore and install the launcher of your choice. Some require background wallpaper options. So my patch allows wallpapers to be used, though you may need to download wallpaper picker.
Where can I find tablet UI?
It is made from the same developer os this one read carefully 1st post
Good Luck
Originally posted by Rudboy View PostRe bonjour j'ai testé toujour pareille toujour même erreur
key mac available 0
un autre avis à mon soucis ?
Va dans ton repertoire où est amlogic burning tools : C:\Program Files (x86)\Amlogic\USB_Burning_Tool
edite le fichier mac_ether.ini
regarde ce qu il contient dans le start end il faut que ton adresse MAC Soit compris dedans et aprés avoir selctionné overwrite key aussi clique sur start là ca devrait marcher
dis nous si cela a marché
Alors Rudboy il faut savoir exactement quel modele tu as tu dois ouvrir ta box et me faire une photo de ta carte de prés là où il ya marqué la version du type
cela ddoit marqué en blanc sur le circuit imprimé bleu version exemple : CZ- S32-V2.32
SUR le lien ci dessous tu trouveras toute les versions a peu prés prend bien celle qui correspond a ton modele et dis moi si ok
sinon tu n'as pas une version WISDOM fait aussi un screen ecran quand tu vas dans parmetres et info systeme
_
OUI Normal donc c'est une version CZ-S32 V6 Dans le lien que je t ai donné c'est la 4 EME REpertoire qui concerne ta version
lien direct : https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!prxFnCRA
prends la version la plus recente : c'est la 7eme en partant du haut du 9 04 2018
ah si c'est juste pour l'interface on appelle ca un LAUCHER ca se change super facile en telechargeant un fichier apk qui se charge comme une application en le lanceant
moi j'aime bien unwind launcher regarde sur le google playstore
en plus tu peux aprés changer le menu demarrage que tu veux pour celui d'origine dont tu parles il est là
dans le meme lien mega que je t ai envoyé sur le coté gauche tu as un repertoire launcher
celui qui correspond a ton image est celui ci ; AmlLauncher_canzone_russian_7.1(23-09-17
tu peux le verifier dans ce sous dossier tu as un repertoire screenshot qui te permet de voir a quoi corresponde ces launchers et ce que ca donne en visu
tu telecharges le fichier sur ton pc tu l'extrais ca donne un fichier apk tu le mets sur une clé usb tu vas sur ta box
explrateur de fichiers tu vas chercher ton fichier AmlLauncher_canzone_russian_7.1 apk et tu cliques ok ca le lances et ca t installe ton launcher
There are currently 2576 users online. 0 members and 2576 guests.
