I managed to use your backup unfortunately this does not solve my problem which is identical. I do not understand why errors that did not exist during my first installation appear after a reinstall. Karl can you install the free STB Emulator application and tell me if it stops at you as well as backdrop screensaver
Originally posted by Morgan5000 View PostI managed to use your backup unfortunately this does not solve my problem which is identical. I do not understand why errors that did not exist during my first installation appear after a reinstall. Karl can you install the free STB Emulator application and tell me if it stops at you as well as backdrop screensaver
to fix backdrop, you must install daydream enabler module in Magisk. I recently made a thread on no-op lean back apps, that explains fixes to get troubling apps operational again.Last edited by X92-2GB; 10 August 2018, 21:43.
Originally posted by X92-2GB View Post
Ha! Backdrop is broken on SCV4a and SCV4A ATV. I think it is because the two firmwares are not complete.
Anyway, I'm currently running SCV7A Rom, since that 4A thing was not very friendly to me. And with my experience from the first round, it was a snap.
I'll see, if that fits my needs and wishes...
During my first installation backdrop was working... This problem is very strange I would like to have the opinion of Superceleron. Do you think Day dream could also repair applications that always stop? When I open STB Emulator no storage permission is requested as on other applications. I think the problem comes from the but it would surprise me that backdrop requires permission. I will try your solutions soon. Thanks X-92-2GB
Originally posted by karlnabb View Post
Hmm. What is STB Emulator ? Atari ST B ?
Originally posted by anys357 View PostHello
So, Mic works on the Youtube TV app and if you update the google app for Android tv on Aptoide you can use Google Assistant
There is no solution to get Google Widevine Modular LVL DRM 1 to use Netflix ?
The Best Rom for H96 pro+
Thanks superceleron
Originally posted by Morgan5000 View PostHello, someone with a green PCB CZ S32 v 2.2 could do a backup of his pristine ROM (scv4a) After factory reset or freshly install to try to solve my previous post problem. Thank you in advance it's been several days since I tore my hair off. I'm looking forward to solving my problem.Last edited by ebabilonia; 27 August 2018, 20:26.
Originally posted by ebabilonia View Post
I got the same box green PCB CZ S32 v 2.2 DDR3. you use the green version? I open the box and the board has DDR3 chip.I ended up telling me that I stumbled upon a emmc storage of poor quality and that a file is corrupt or illegible due to Several handwriting even if two installation seems to me little for damaged memory emmc If you find a solution I'm a taker.
Yes we own the same box I am also in DDR3. You also have an application crash? At the first install of scv4a I had no problems following the reinstallation several applications that worked crashI ended up telling me that I stumbled upon a emmc storage of poor quality and that a file is corrupt or illegible due to Several handwriting even if two installation seems to me little for damaged memory emmc If you find a solution I'm a taker.
To fix first need to disable chrome. The check is Android System WebView is enable and update with play store.
Now Staker, pix and mitv+ work perfectly.
Did not stay on SCV4 on my box. Moved on to SCV7a, updated chrome and system files, the only issue is that 3 newer versions of mobile streaming apps crash. Nat Geo (US only), STV (Scotland) player, and SBS on Demand (AU). IMO Webview is not as good as Chrome. Just need to make sure your Chrome and Play services are updated regularly.
There are currently 3528 users online. 1 members and 3527 guests.
