And now that gearbest stopped supplying me boxes, it means my roms to newer boxes will start to show even less since i cant buy all boxes out there...!
superceleron
Why not to collect the money for the needed box in here? People could donate you if they want new roms
@hcardoso483 ; @ch3mn3y
Thanks for your help. indeed to go from V7 to V4ATV I pass in firt by the intermediate stage of the V1 ATV.
Yesterday I updated usb burning tool to the latest version 2.1.6. with this version I managed to move to the next step but without success. another error
dada06200
It's not possible to fix it. I just checked with Google and it seems MyCanal and Canal Play apps need Widevine L1 and our Box has only Widevine L3. You need "better" Box, like Xiaomi TV Box or a Nvidia Shield or any Chinese one with L1 support.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
hcardoso483
He already found what was the couse - #777 (http://freaktab.com/forum/tv-player-...286#post730286). USB drivers were wrong.
As for "mac keys". Did You mean license of Burning Tool? Coz I believe that with broken/missing keys on the device it still should flash the image, as it's an software issue, not hardware one.
only that after flash and launch of the Box WiFi, Bluetooth and Ethernet connections could not work.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
ppoon
Yes it's possible, but it have to be 5V charger as some people already burned their Boxes by using 9-12V chargers.
Just use one with higher amperage - 3-4 A should be enough for 4 USB ports working simultaneously.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
michcio87
This Box doesn't support Widewine L1 (only L3), which is needed by Netflix TV app to work and nonTV to show HD+ resolutions.
There are apps with "unlocked" HD streaming on Widevine L3 devices, but does they really work? Maybe before.
Only way is getting a Box with L1 support like Nvidia Shield TV, Xiaomi Mi Box. There are Chinese Boxes with that level of Widevine codec (e.g. Mecool M8S Pro and Mecool M8S Pro Plus), but not this one.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 4020 users online. 0 members and 4020 guests.
