But You could just get log and last_kmsg after reboot (it's best to reboot straight to TWRP). It should contain needed data.
CatLog is my first choice for reading Android log. However I'm not sure if it works as reader or only as real-time debugger.
But You could just get log and last_kmsg after reboot (it's best to reboot straight to TWRP). It should contain needed data.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by Intelian View PostHello. First i would like to say thank you for this great rom! :-) I have a question about the build-in Chromecast. I believe i read somewhere that it is not possible to get it to work.. so my question is... is it possible to completly disable it somewhere in the settings? It is a bit annoying that the "Chromecast screen" shows up while a videofile is paused ( during a phonecall ect.)
Thanks in advance :-)
M.
Hey,
I have install the latest version of this rom, but I can't get passthrough working and DTS-HD reconized on my AVR.
On libreelec passthrough was OK in kodi with the same box, so that really a wonder to me...
Any idea ?
Thx in advance.
Edit : I do have HDMI raw activated in the settings
Edit 2 : Kodi have the HD-audio option, but not FTMC, but kodi struggle with 4k vids...Last edited by bounty1342; 05 March 2018, 03:43.
Any idea ?
Thx in advance.
FTMC is based on Kodi 16 - no HD output there.
This is one of the main reasons I run (24/7, because of power on-off issue on LE) libreelec on my box (fron sd-card) . SC Android is still there and its very good, just not for watching movies...
Thank you very much great job
Flashing it with Usb Burning tool 2.0.8 work great had a blue board device
Only some question how I can install PVR Client in FTMC or is that not the right tool for it of course i can install kodi normal over playstore but want to test simple iptv with FTMC or did some one know a better app for it
There are currently 4036 users online. 1 members and 4035 guests.
