    Hm,
    now, I am not sure what to do.
    My model is Wisdom ZH01-S912-TVBOX- V3.0 green PCB.
    When I ordered a Box I thought that there is only one model that works correctly.
    When I plug on the box for the first time It obvious that there are some problems with it.
    Work was unstable. I need several times to plug on and off, many freezing, service stopping, crashing. Mostly I couldn't get it to work at all.
    Firs idea was factory reset - no use.
    Then I found how to reinstall firmware on youtube. I tried with SD card and brick it.
    After that I managed to fix it over USB cable - not sure which ROM I used.
    Looking for support from Gearbest - ROM from their support page also brings unstable work as original one.
    They offered me to return item on my expenses and they will resend me another one or they will refund me amount for item on GB wallet for another buying or pay additionally 35 $ and they will resend without returning one that is with me.
    Since I spend enough, even more then I planned for TV box (costumes expenses), my decision was to pay addition money for one that will work correctly (sending from Croatia to China is about 30$)
    After reading yours posts I think that I will have two useless TV boxes at the end.
    This is my experience with GB - maybe it will help someone in future buying.
    Regards to everyone
    PS. Sorry about my English
      ok first it s esay to identify your problem
      when i say your tv box is bricked there s three possibility
      when your open your box first take power on if you have light blue or red and on your tv that s stop on screen H96 PRO+ that s SEMI BRICKED
      YOUR must started on recovery mode insert a toothpick or tip into the small hole on the left side of the device
      plug your power after and when the box start is arrived on this menu
      for resolve the prb boot that s just necessary to go to mount system and after reboot now
      or for go to factory reset you see on the menu there choice wipe data first and after go to choice wipe factory reset and after reboot now
      the rom you used is here only model wisdom
      3 possiblity : your box have no blue light no red light no light on SPIF out
      no connexion in recovery mode on pc witi usb cable male male with usb burning tools ( no sucess connexion )
      the box is completly bricked is t s necessary to take short pin on pcb for have connexion succes ( this mode is on mask rom )
      i have find the screen where you see the shortpin circuit for wisdom pcb ZH01 S912 TVBOX 2.0
      BUT see the pcb is the same at you is ok
      go to this video you tube for usb burning tools procedure : https://www.youtube.com/watch?v=BBQbuZSeOJE
      and here if is completly bricked : https://www.youtube.com/watch?v=Hgw4S6RgRBE
        Originally posted by fatbottom View Post
        Is it fixable with a OTA update? (codec patch)
        hi superceleron i had same video playing issue, and changed my rom to a nexus one ( Alfawise S92 TVStock Nexus ROM). its works something bulky. maybe a clue?
        • superceleron
          superceleron commented
          Editing a comment
          Like i said is a codec problem, dunno if i cant fix it... since is nearly impossible without the sources!
        Hi Superceleron and conpany i installer this rom ( marvelous )but i can not write on hard disk externar from kodi or ftmc, i instaled root,xposed etc everything working and delete files from filesmanager etc but not in kodi o ftmc how can i write/delete in this app??
        obviously the option to delete files in kodi I have it activated Thanks
          Did you install this ROM on a H96 Pro+? And there were no codec issues with that ROM?
          Maybe I misunderstood what you are saying.
            Lacix
            yes i installed rom that you linked and i have no codec problem. no pixellation or macroblocking. But sometimes my box slows and frozen on this nexus rom.
              please dose this support H96 MAX ROCKCHIP ROM
                Dear all, sorry if this question has already been asked, but anybody know if this custom firmware work on TANIX TX9 PRO (box have same feature like Alfawise H96 Pro
                thank you in advance for answer.
                  Deki
                  Don't think so. It won't even work on all variants of H96 Pro+, so I would say that Tanix is out of the question. However You may try it. There is huge chance for brick, but if You won't try, than You won't know if t works
                  ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
                    ch3mn3y
                    Thank you for your reply solution is not brick my box i search other firmware again thank you for reply.
                      Lacix
                      If I knew which file (codec) needs to be replaced from the other firmware to fix the issue I would try it. (I've downloaded a tool which can extract amlogic firmwares)
                      If someone knows it please share.
                        Hi!
                        Can someone help with my case.
                        I have a GB H96 Pro+ 3Gb/32Gb that came preinstalled with wisdom q201_9377-userdebug 7.1.2 NHG47L 20171020-testkeys rom.
                        The rom was buggy had some problems with lan connection (was not linked after restart) so after few resets started working again.
                        I decided to reflash the box with celerons image, but as I found later no rom is working.
                        using usb flash tool 2.1.2 and corrected licence file I always get error messages when flashing.
                        I managed it to revive with this version of wisdom image : https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!Bqo1FDoQ
                        but now the wifi doesn't work, and also some apps are still buggy
                        I also have discrepancies in version of the PCB and RAM??
                        I have a green PCB, but the hynix ram chip specification is DDR3:
                        Photos:
                        I am searching for a good working wisdom/working rom or any other advice.
                          I just got the H96 Pro H3 version with S905X and 5GHz WiFi, it would be highly appreciated if someone could port a ROM for this version.
                            Originally posted by odyssey77 View Post
                            Hi!
                            Photos:
                            I've bought about a dozen H96 Pro+ boxes for resale and I finally got one of these boxes. I've tried countless firmwares, they either wouldn't flash or if they did flash they would just constantly crash. The only one I've got working on these boxes is https://mega.nz/#!3c4HhChY!pU8S1zAUA...GruaKc2lSD13jE
                            It isn't the newest one I found, but none of the newer ones would work without constantly rebooting or crashing apps.
                            It's not the best solution, but it's the only one I've found. Hope it helps.
                              Hi!
                              Thank you, the box flashed ok, but sometimes It craches on wifi connection.
                              this rom is at least 80% working.
                              If someone is having q201_9377-userdebug 7.1.2 NHG47L 20171020-testkeys rom please contact me!
                              BR
