You have to open the Box and check color of Your PCB.
If it's blue than You use image for blue.
If it's green than You should use green one, but there is so many variants of green that it may not work (however it seems to work on most of the variants of H96 Pro+).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by Lacix View PostAnyone else getting total freeze in sleep mode randomly?
Which log file viewer app is the best to find the cause?
I had to disable the camera application (google?).
I've turned off the box one night and the next morning it was on. I hit the turn on/off button on the remote but nothing happened then I hit it multiple times and then it turned off and then turned on again.
I've checked the tv and it has shown multiple dialogs about that the camera has problems. (I don't remember the exact texts)
After disabling this built in application the freezing disappeared. I am wondering what tried to use the non existent camera. I've only installed Magisk, Total Commander, Kodi, Throughput Test Client, VLC, Plex.
Rochina37
Why? Almost everything is working and things that doesn't may be not fixable. Superceleron wrote (however in thread about Normal rom) that he MAY update it one more time. But MAY os the most important part here.
However I don't see reasons why there is update needed (however that doesn't mean I wouldn't like one :P).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by Rochina37 View Postalguna actualizacion de esta rom para un futuro no muy lejano ?
If You flashed SCV4 than it should already be installed. Just disconnect power cord, push reset button, connect power, but keep pushing for like 5 seconds (or till You see TWRP screen).Last edited by ch3mn3y; 17 March 2018, 16:14.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1233 users online. 0 members and 1233 guests.
