M.
Well that option is a "hit and miss" since is not planed to work at all i dont really mess to much with it... if it works it works, if wont work it wont work...
On my phone it worked, maybe on other dont who knows... googlecast will never work ok.
than, is there a way to turn it off completely?
Thanks,
M.
bilna
Use USB Burning Tool. File->Import Image->Coose downloaded image (after unpacking downloaded archive). Than connect, using USB male to USB male cable, powered off Box and click Start.
However what kind PCB You have? I don't mean a color, but it's "name".ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by bilna View Posthello, I own AlfaWise H96 PRO + 3/32 with a green pcb. I did download SCV1 GREEN PCB IMG. Could you give the installation procedure?
should a USB cable or SD card is sufficient?
Thank you in advance for your help
follow the links:
-RK3368 CSA91/R8/R68 V2, V4
Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
OTA is update of the system and the system apps it has.
It doesn't have to be installed, but I think better to use it.
However some people reported that after OTA their Box is bootlooping.
I would recommend to boot TWRP manually and make backup of whole OS. If something happen You will be aple to restore SCV1 as it is working for You.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
hi superceleron I have tried your firmwares and I have to admit that your work is flawless and brilliantly done!
I have a question if you don't mind please, both on Android TV and Normal versions I am unable to use both Smart iRemote app (from my Android mobile) and a Rii mini i8+. Anyone can test and let me know if it works for you?
There are currently 4281 users online. 0 members and 4281 guests.
