Originally posted by haraferraz View Post
C'mon man, do a research first.
Android TV version is the version that comes with Nvidia Shield, Nexus Player and Xiaomi Mi Box.
It's the official Android version that Google made for TV boxes.
Advantages:
- Leanback launcher (for some it's a advantage)
- YouTube and Netflix running at 4K max resolution (the only reason to install this version)
Disadvantages:
- Different PlayStore that only installs TV optimized apps (very limited)
superceleron I am having an issue with Plex and Android TV. Anything DTS I have no sound. I have searched and searched on the web and I guess this is a known issue. Are you aware of this issue and if so any way to fix / adjust the rom build?
Advantages:
Disadvantages:
Originally posted by ciechon View Postsuperceleron is there any way to make an android tv version for the new H96+pro (Gearbest) Wisdom version? ZH01-S912-TVBOX-V2.0?
I'm in the same 'boat' as you are. I recently purchased the Alfawise H96 Pro+ from Gearbest and got the box with 'only' 2 USB ports (without the 'hidden' extra 2 USB ports), with GREEN pcb and 8 memory chips (instead of 4 chips). It came flashed with 'Wisdom' fimware from Sep. 18.
I'm wondering whether anyone got the same unit and managed to install superceleron firmware on it.
ciechon, let me know if you managed to find a better/optimized firmware that works on our box.
Thanks,
Zach.
I'm getting a "Data Transfer Error" at 17% during Download system.PARTITION phase of the burn and stock firmware flashes to the box fine. I've done something like 10 of these boxes already with no problem. I know these things can be fickle, they travel a long way to get to me and they aren't packaged that great when they get here. I may have to just put up with the stock rom unless anyone has any ideas.
Originally posted by zachig View Post
Thanks,
Zach.
Originally posted by Vagueabond View Post
i had the same problem, maybe you have old boot android installation files on your sdcard, try to format eh card in fat32 and copy/paste on only the update/
I have a problem with the application "MyCanal" for watching TV, it doesnt work , i ve only sound...
with the V1 only the sound work
with the v4a the application crash
I found one solution for me. Maybe for you it's the same :
With v4a version :
Install aptoideTV
search chrome, install the last version ( now 62.x.x )
after start mycanal and normally it will work
J'avais le même problème que toi sur Mycanal
Seulement le son et une image fixe avec la rom V1
L'application ne se lançait pas avec la mise a jour V4A
J'ai trouvé une solution qui marche chez moi
J'ai installé aptoideTV ( plus pratique pour naviguer )
j'ai installé la dernière version de google chrome ( 62.x.x )
J'ai relancé Mycanal et ça marche
I have just bought the Amlogic S912 H96 Pro+ 3gb/32gb which came loaded with Android 7.1.1 (pics show as DDR4 with green PCB)
It is constantly crashing and from what I have bee reading this is not a new problem.
I would like to upgrade it to v7.1.2 which is known to work much better.
Superceleron, I have tried to load numerous ROMs for this model, including SCV1 launched in this thread.
Everytime I load it with USB burn tool, I uncheck "erase Bootloader" which lets me complete the burn process without errors.
Although, the box does not boot or does nothing at all when I plug it back on the HDMI and power.
To make it work again I have to reflash the stock ROM with shorting pins 29 and 30 of the chip.
What can I do to make your ROM install and work on the box?
What am I doing wrong?
Your help and suggestions will be greatly appreciated.
Thanx
Originally posted by hmsr21I have just bought the Amlogic S912 H96 Pro+ 3gb/32gb which came loaded with Android 7.1.1 (pics show as DDR4 with green PCB)
Thanx
Sent from my H96_PRO_PLUS using Tapatalk
Originally posted by Ninodr View Post
Me too,if somebody could help us ,you are welcome
(photo here: http://freaktab.com/forum/tv-player-...-from-gearbest)
V
There are currently 2935 users online. 1 members and 2934 guests.
