Hi all,
I just bought a generic H96 Pro Plus 3g/32gb from amazon but it freezes quite a bit. Looking thru the vent on the back, the Blue board.
My question is that if I need to open the box for chip ID? Or this firmware works with all the generic H96 Pro Plus without open the box to find out the chip?
Since it's generic, my concern is that it will be hard to find the current firmware loaded on the box, meaning once loading other firmware, it will be no way to load back the original FW.
Bought from amazon https://www.amazon.com/Update-Versio.../dp/B074H99B8FLast edited by dtsexpert; 15 January 2018, 03:48.
Lacix
No, it's not, Sometimes with some devices it may work, but mostly it won't.
dtsexpert
It would be better if You could open it. However till now there were 2 blue PCB variants of H96 - S32-V4 and S32-V6. Both supported by superceleron's roms.
Still, it should be one of them, but what if there is another version? Newer or rarer?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hello everyone, thank you very much for the work of the Rom, I have an Alfawise H96 Pro Plus 2/32 Purchased from gearbest "I think I'll be the only one to have it" with Green Pcb I wanted to ask if it was possible with some changes to solve the problem that do not restart with the remote control, the TV box remains off. Are you aware that both the twrp and the TV box access, you can not restart the system because the box turns off completely, it will be a bug? I apologize for my English, I use the translator. You can use Supersu? Because titanium Backup does not have all the features available if you root with Magisk, the menu key is missing to restore apps with titanium Backup. Thanks so much superceleronYou may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by Yugo79; 18 January 2018, 21:29.
Then it is the ROM that has problems with titanium Backup, because even by running the root with supersu, titanium Backup has limitations. I still use titanium on beelink and mecool and I have no problem. Is the development of the rom of this thread stopped? The last update dates back to past months. Thank you
"L1" means Level 1 of Wideline DRM, which are needed by. Netflix - ATV app won't work at all without it and mobile one won't let You to watch anything in HD (or better) resolution.
Netflix needs not only L1, but "Netflix certification" of the device, however it is possible to make Netflix show HD+ video without that certification..ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Anybody else has problem with video playback?
Only good playback results (no pixelation/blocky picture) if hw acceleration is turned off in Kodi.
Sample file: https://drive.google.com/open?id=1W5...6KUgFEYu1v3I7H
On TV: https://drive.google.com/open?id=1yC...RPUfUB_mKN2Idn
Originally posted by Lacix View PostAnybody else has problem with video playback?
There are currently 1389 users online. 1 members and 1388 guests.
