M.
mikka005
All I can say that I do it like this: Start Tool -> Open image -> Wait -> Connect Box -> Sometimes it's seen, sometimes it's not -> Reset it for 3-5 seconds (better 5) -> It's seen - Click Start -> WaitALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Don't think why not. But I have 2.0 only and it works, so maybe it would be better to buy 2.0 cable?
And are You sure that You have compatible device? Maybe it's sign from Odin, that You shouldn't mess with Your toy?
Truly I don;t know if mine is booting to recovery or what as I do it without having Box connected to any display.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostDon't think why not. But I have 2.0 only and it works, so maybe it would be better to buy 2.0 cable?
I will buy a 2.0 cable, than try again.
Thanks,
M.
mikka005
There are so many different H96+ that just having one is not enough to make this Rom work. If You have just got it, than You probably have same device as mine (blue, S32-V6), but better check it before flashing.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
agrinevicius
Have to change one of my answers to Your questions: TWRP does see FAT32 formatted flash drive. Don't know why it hadn't before, abut it did few minutes agoALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Everything works fine.
elvis3002
Don;t know, as I flashed it almost right after flashing V4 (only set it up on V4 and than rebooted to to TWRP to flash V7A).
However I don;t see any problems. DLNA is working fine, connected BT keybord (couldn;t manage to do it on stock), AirMouse is working too.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
hello Stk00 quelle version avais tu d origine je pense 7.1 car pour moi j ai essayé en premier cette technique
bien sur la c 'est juste la photo mais meme si marqué m8S PRO+ c'est le meme menu sur ALFAWISE H96PRO+
qui n'a rien donné en premier lieu car d abord la fonction reboot n est pas effective l alawise s eteint mais ne se rallume pas seul tout noir il faut debrancher la prise d alimentation et la rebrancher
PAR CONTRE la fonction eteindre chez moi ne fonctionne pas a 100% EN EFFET quqnd j appuis sur le bouton off de la telecommande j ai bien le menu eteindre ou redemarrer
j appui sur eteindre ca mouline ok puis ca s eteins mais reste le boitier reste en led rouge et si appui rallumage par la telecommande ca marche pas
Pour éteindre ta box il faut que tu mette dans les options d arrêt sur redemarer j ais eu ce problème aussi sur un modèle ensuite pour la flancher il fait que tu la démare avec le bouton de réinitialisation appuyer et le relâcher quand ta box rentre dans le mode ensuite tu pourra flacher en sv4
Originally posted by dangchui View PostPAR CONTRE la fonction eteindre chez moi ne fonctionne pas a 100% EN EFFET quqnd j appuis sur le bouton off de la telecommande j ai bien le menu eteindre ou redemarrer
j appui sur eteindre ca mouline ok puis ca s eteins mais reste le boitier reste en led rouge et si appui rallumage par la telecommande ca marche pasALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1603 users online. 0 members and 1603 guests.
