Originally posted by chenrp View Postsuperceleron
does your rom has this rom fixes:?
http://freaktab.com/forum/tv-player-...c_mac-20170826
Subtitle service works just fine etc....
Originally posted by nakti View PostWhats the difference beetween SCV4A OTA and SCV1 IMG?
So do I need to flash SCV1 IMG first by Card maker or burning tool? And then update to SCV4A via TWRP which is getting installed from SCV1?
Does anyone have step by step guide to install this from stock rom?
then format the microsd , put the zip SCV4A on it and use the update App on the box.
Since i'v upgraded to SCV4A im getting crashes in video decoding. For example the app accuwearher only plays a video after boot then not even youtube can play, just keeps spinning the wait screen. Also i use stream.io a lot and some videos when the source stops to buffer cause the app to fail with an error related to hardware decoding failure.
Definitely not stable this SCV4A.
How can i help to diagnose this further?Last edited by chaveiro; 18 October 2017, 13:50.
Originally posted by chaveiro View PostSince i'v upgraded to SCV4A im getting crashes in video decoding. For example the app accuwearher only plays a video after boot then not even youtube can play, just keeps spinning the wait screen. Also i use stream.io a lot and some videos when the source stops to buffer cause the appntobfail with an error related to hardware decoding failure.
There are currently 2477 users online. 1 members and 2476 guests.
