I've tested http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4 that is an earlier GT1 superceleron modded for the Alfawise and liked it, nice features like be able to show net speed and cpu temperature on the toolbar, good stability, etc.
The rom of this thread seems fine but i've discover already a few errors, app no responding and the more setting crashing.
This lead me to this questions:
1 - How does this rom compares to "Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)" and how they will evolve?
2 - Why different ROMs for different box, but the same hardware, all from superceleron, get different features ?
ThanksLast edited by chaveiro; 24 September 2017, 12:50.
Originally posted by fabulon View PostI've bricked my h96 pro+ with a maj by sdcard.
When i turn on the box, there is no signal on the tv screen.
Can i repair this?
Had something similar..
The box default the outputs 1080p 60hz
My TV is only compatible up to 720p 60hz so it wouldn’t show an picture, I had to plug the box into a 1080p TV and change the settings to 720p
Hope this helps
Hope this helps
This is not the problem.
I have to put another rom. But which?
Super ROM, everything works so far, FTMC do not support DTS passthrough, new KODI v17.4 do
I used your rom on this one, just says 4K on top of box
https://www.aliexpress.com/item/Genu...757058161.html
Works just as great, except no Dolby Vision support, which they stated and i expected to see working. (LG OLEV C6)
Anyways perfect install, even ADB remotely works fine and who cares about the old settings, probably just a few functions here you would need.
I cannot verify Youtube UHD working, it just says HD here, same with Netflix i have to use custom netflix apk to see "UltraHD" logo, but i cannot verify bitrate.
Maybe some one knows if HLG HDR, or Dolby Vision did work ever on these boxes?
already had the files for hdcp2 license in my burning tool folder, from a previous flashLast edited by collectordk; 29 September 2017, 16:48.
There are currently 2655 users online. 0 members and 2655 guests.
