That is normal is because of different bootloaders!
Originally posted by pfornaro View Post
Could you please tell me how to flash through SD card, plese? I would avoid USB burning tool since it scared me the last time with those plug in/off and several attempts to flash the ROM. Thanks in advance
To install after flashing, power off, press reset pin with paperclip or so, power on and release paperclip after a couple of seconds
I tested the ROM for a while yesterday and it looks very promising. I do notice tearing in 4K video after a while though, I suspect this is caused by the chip getting too hot. Also, Plex is somehow not really working as it is transcoding both audio and video for assets that play out fine using Kodi. Any feedback/tips on this matter are welcome (not sure how Plex determines which codecs are supported?). Last, I hope the Android TV version of Netflix will work at some stage. The current mobile variant is not ideal imho.
Originally posted by straumli View Post
Check this guide with screenshots: http://www.techzbyte.com/2017/02/how...vices-via.html
I could also not get chromecast to work (device was not detected)
What about the Powerbutton when the box is shut down (not standby), does power up via IR remote work for you guys?
Originally posted by derbundy View Post
Same here for chromecast. When installing a third part chromecast tool, it works. Airplay works sometimes but not as stable as it should. Iphone airplay connection with amazon video does not work at all (and amazon prime video app will crash with this build, when installed on my box). So the streaming part seems to be a bit buggy right now
@superceleron: Not sure if possible/allowed, bit if you host your builds on e.g. github we might be able to track defects and feature better?
Originally posted by derbundy View PostWhat about the Powerbutton when the box is shut down (not standby), does power up via IR remote work for you guys?
Single press puts Android to stand-by and wakes up instantly
Long press allows to select shutdown/restart and when box is shut down, the power button starts the box.
Originally posted by straumli View PostLast, I hope the Android TV version of Netflix will work at some stage. The current mobile variant is not ideal imho.
Originally posted by futr0 View PostCould someone confirm chromecast capabilities actually work on this ROM?
Also, I was testing video playback and 'adjust display refresh rate' doesn't work. Tested on both SPMC & FTMS.
IR power down/up works for me.
Besides im stopping developing in for this device for some time, i have lots but really lots of other boxes to update and some to make new roms....
There are currently 1416 users online. 1 members and 1415 guests.
