But why is it fine with the GT1 ATV firmware here http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4 ?
Originally posted by chaveiro View PostBut why is it fine with the GT1 ATV firmware here http://freaktab.com/forum/tv-player-...ndroid-tv-ddr4 ?
Nice to know you have been working on this rom.
I'v updated mine to scv4 but i'm having a few issues:
1- The top bar shows up after entering the appdrawer and on every app even while paying youtube videos and i cant hide it. Bottom bar does hide. Am i missing something here?
2- Chrome cast works with youtube as you said but always crashes when i end on the sender side and then does not work again on the box until i reboot it
3- Power off via the lower menu bar button does shut down the box with a red led, but the original remote does not turn it on after. Need to power cycle. Hdmi CEC power off and original remote power button still work as usual to sleep/wake up
4- The menu of some regular android apps (as i said on a previous post) still does not work.
Great Work Superceleron ! Excellent ROM. I've just updated to SCV4 and I would like to thank you for putting back "Advanced Settings".
However I've got a problem, in nearly everyapp I use (example youtube) upper status bar is always appearing. Is there a way to hide it or disable it completely ? Thanks in advance for your feedback
Ok i am having ghosting effect on video file playing on ftmc. Previous screen ghost image shows in next screen and also have motions blurrs.see images THIS is in SCV4
Problem is with Amcodec acceleration and little bit on software acceleration( only on FTMC) with mediacodec at this point of video the graphics glitches so i am not using mediacodec at all and that is why i need FTMC because of amcodec support.
Hi guys, I'll finally have my H96 this week. I am very interested in flashing this ROM but I would ask if the original remote works because. This is a feature I really need so please let me know. Also, I hope superceleron will remove again the two bars since I (and I think I'm not the only one) got really annoyed by them.
Hello
pfornaro, remote works fine (at least navigation buttons, volume, power button the most essentials one that's the only buttons I've tested)
Otherwise, I found a workaround in order to remove upper bar
either with adb
adb shell settings put global policy_control immersive.status=*
Or in a terminal type :
It seems to work fine now.
if you ever need to rollback
adb shell settings put global policy_control null*
There are currently 3606 users online. 0 members and 3606 guests.
