Hello
superceleron, Can you explain how you do to make IMG for LPDDR3 ?
I extract DDR.USB of your file TEST IMG, and i put in the other image with CUSTOM TOOLS. But it's not OK. The box don't boot.
What is the solution ?
Thank's a lot
Bye
Thank's a lot
Bye
Originally posted by yzon81After updating to the latest version, the Rii mini i7 remotely stopped working correctly. Home button does not work
Box S10
See by app usb host controller the name of the device (my is vendor 1997 product 2433). Go in folder (with root) root/system/usr/keylayout and open the file with the name of your device .kl and personalize the keyboard here.
Inviato dal mio SM-G935F utilizzando Tapatalk
Originally posted by 2xtreme View PostHey guys,
What are the differences between this and the non ATV version?
Android TV version is the version that comes with Nvidia Shield, Nexus Player and Xiaomi Mi Box.
It's the official Android version that Google made for TV boxes.
Advantages:
- Leanback launcher (for some it's a advantage)
- YouTube and Netflix running at 4K max resolution (the only reason to install this version)
Disadvantages:
- Different PlayStore that only installs TV optimized apps (very limited)
Originally posted by Scroful View PostHello i Try install scv1 rom for h96 pro plus buy on gearbest on september 2017 using usb burning tools. Impossible erase bootloader identity error result. À solution ? Because the original rom cant launch YouTube playstore app.....
When i have the time to do it i will make the img!
Ok i changed pc and now i did it,but i connected to tv but it doesn't work i tried 20 times i guess but never start at all (after 30min)or crashes every times,it doesn'go in recovery twrp and there are several pixels that are going such on/off in the screen,sorry for my english...but what i have to do exactly,because is not usable now..the ota i insert in sd card in zip and install it throug local ota,but i don 't know is the same thing...the tv box go black screen and till after 15 min is tge same ,so i restarted but i don't know if i wrong something or what.
Hello everybody. I cant Install custom rom on my alfawise. Il have stock rom user test 7.1.2 but i have also bug with issue on YouTube navigator system.... I join you pics of my box inside i bought on gearbest. I tried i think all your custom rom normal and atv. Sometimes it crash at 7% or 95% error partition etc....
Thks if somebody can help me or super celeron. I bought a Big mâle mâle usb for the occasion.
There are currently 2602 users online. 0 members and 2602 guests.
