dangchui
I know, but there are people who would do something like that (using older version of something, coz it looks GOOD).
And I I don't know if recovery.img file placed on sdcard hasn't higher priority than one flashed to recovery partition. That way it could be booted even if there would be newer version available on that partition.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
atysh1
Basing of what is written here: http://freaktab.com/forum/tv-player-...ponent-changes, You should use image for green board. And as it's probably true (there were 1 or 2 versions of DDR4 board, all green), I would still check what really is inside.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
atysh1
And that's just it?
Seems it doesn't match any form that thread - there is only TVBOX - v3.0 (but with DDR3 memory I think).
Than You can try to flash this Rom, but it may not work for You.
So it would be the best to ask seller for firmware image for this version of H96 Pro+. In case of problems.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View Postatysh1
And that's just it?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello
Have a H96 Pro + with blue board but no Alfawiese I can still use this firmware ? Can I change the color output to RGB in the firmware ? ThanksLast edited by Dericetiger; 20 December 2017, 15:37.
There are currently 1295 users online. 0 members and 1295 guests.
