    Hello, I have problem with live channels, when i play some channel or play movies preview i have black bar on the bottom of screen... not by aspect ratio its shows everytime only on bottom... have somebody this problem too?
      What ratio is the movie? If it's 2:35 that's normal, you want to keep the original aspect ratio. Zooming in will look crap.
        Marcus Vinicius Brito
        I think that You do everything all right. All I can think of are wrong app version, problem with cable and broken drivers.
        ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
          Tried to create a custom boot animation but only getting black screen at boot.
          Can someone look what is wrong?
            Thank you, but I tried everything and nothing of this box work I think it came with defective manufacturing
              I installed this on my gearbest Alfawise H96Pro v3. But since it is not possible to bypass wifi in the initial setup, I never made it past the part where it is "looking for updates".
              Dont know why this happened, if my wifi signal was unstable or if it was the box.
              I then installed the non-AndroidTV version, and it works well without any wifi issues.
                If You prefer ATV Rom, than after flashing and getting stuck on the first setup, go to TWRP and remove SetupWizard (and any other Wizard) folders. Than it should boot straight to homescreen and You will have to set it (WiFi, Google account etc.) by Yourself.
                  Thanks for this information. I have only used the other rom, so I dont really know what I would be missing from the AndroidTV version. So far I feel quite happy with the normal version.
                  But I guess I could just make a TWRP backup of my current rom and flash the AndroidTV version again and test this.
                    I tested both and chose Normal one as ATV's Google Play has less available apps than Normal one. And as there are more apps supporting Normal than ATV (not counting apps supporting both), than it's easier (meaning faster) to manually update ATV apps on Normal rom using apk files than Normal ones on ATV rom...
                    I have 2 ATV-only apps - Netflix (doesn't work but I kept it) and YouTube. I use ApkMirror to upsate them and Pushbullet to keep track of updates.
                      Hello, superceleron:
                      I hope this letter finds you in good health, my name is Tim Chan from China.
                      I unintentionally got the TV box free of charge. I will tell you how can be free later.
                      When I got this TV box, I found the original ROM was limited a lot; For example: Unable to install app by myself; can’t see YouTube and too much Ads when watching video. We would be much appreciated if you can help us make a firmware based on the Primary Android ROM, and of course we will send you this TV Box for your research and testing. (Free charge&free shipping) Also, if you need some test volunteers, We have a fairly basic number of friends using the TV box whom with great pleasure to do so.
                      Purchasing at the original price (RMB:999 Aka US$147.0) to buy this TV box, I’ll get a “K-code” in the same time when I got the box, then activate the “K-code” on a finance company (WanJia). After 120 days later, “WanJia” will pay me (RMB:999 Aka US$147.0), That means, I can get this TV Box free. Of course, there's only one chance per person. (Based on person ID.)
                      It’s a new way of marketing in China, as far as i know, the company called PHICOMM running in this way for more than 3 years. Product included WIFI-router, Air purifier, WIFI-HUB, Sweeping robot, etc. This marketing program seems to be running well~
                      Please feel free to let me know how do you think about this TVbox, and do you have time working on it?
                      Thank you in advance & Best regards.
                      • superceleron
                        superceleron commented
                        Editing a comment
                        sorry m8 i cant help you with it, maybe another dev can help you...
                        I cant help you because i already work for a company that makes software for some of this boxes and i work for them exclusive, in our agreement we agreed they let me continue my "free" work and that is it... free work and not for a particular box or company and if it wont interfere with my main work...
                        So that is why i cant help you, you got to me a bit late :/
                        Good luck with your project, and i hope other dev can help you!
                      Hello,, superceleron :
                      I really like this rom but would it be possible to fix YouTube for use with a microphone because it's so convenient.
                      Thank you for all the work you do.
                      EDIT: in fact it was just my microphone that did not work. By changing it, everything works very well
                        Hi everybody,
                        I am pretty new in this sport amd I am looking for some help,
                        I paste my problem on several topics here but without any luck so far.
                        Bought H96 pro plus Alfawise 3/32 from Gearbest about a month ago. Since then I am trying to find a ROM that will work without crashing, but without any luck.
                        Is there anybody who can tell me which ROM is suitable for my box. It's green PCB ZH01-S912-TVBOX-V3.0.
                        Thank you in advanced
                          It's not compatible with this Rom or the Normal one. Maybe there are some official firmwares to flash if You want to update Box or it's soft bricked, but I don't know.
                            hi ch3mn3y my box work with this rom
                              Ooo. Good to know. Now I won;t say that it doesn't.
                              I think somewhere between older posts someone with this variant of H96 had problems after flashing this Rom. That gave me idea that it's incompatible.
