What if You remove/freeze/disable LeanBack? Than it should boot what's available (meaning Nova).
HELLO FOR SUPERCELERON
I have always problem with google account i explain i do a backup with twrp for my install and for one of my friend who buy same box tv when i restore my backup in box of my friend i would like to add google account of my friend for delete mine after but there s crash error
same thing if i delete first my google account if i would like to add google account there crash error
what is the solution
Hello!
I have a question: Does anyone succeed in getting SPDIF optical audio to work?
I'm connecting my H96 to multimedia projector through HDMI, but audio is connected via optical to home theatre receiver (good old Yamaha) - still, in spite of setting output to SPDIF RAW, I still hear the sound (e.g. from Netflix) form poor small projector's speaker...
I'm bit desperate already as research on the Web didn't bring any good ideas.
Any help will be most appreciated
My TV Box runs so far on full stock software.
Hi Guys
I Just want to know if SCV4A will comply with the statement below? In other words will the DSTV Now app work on this firmware?
I know the firmware is not rooted, but is play store side loaded or something?
I am from South Africa and DSTV (Sat TV company) is strict on this now.
The following FAQs from the DStv Digital Media team.
What Android devices do we support?
Only Android devices that are Google Certified are supported.
We use the Google SafetyNet API to ensure that devices are not rooted (including factory rooted) or have a tampered boot loader. SafetyNet also ensures that the Google Play Store is supported by default on a device and the device is not running a side loaded version.
We do not support side loading the DStv Now app on devices, the app must be installed via the play store.
DStv Now used to work on my device, now it doesn’t. What has changed?
DStv upgrades it’s security requirements from time-to-time to comply with rights agreements from our content suppliers (and they update their security requirements on an ongoing basis). This may impact devices that don’t comply with these changes.
What versions of Android do we support?
We officially support Android 4.4 and up, the app may still work on some older versions of Android.
Why does Showmax work on some devices and DStv Now doesn’t?
Due to differences in rights agreements with content suppliers the services may require different levels of security.
The head of our online services, Byron Linsell, has offered that anyone with technical queries can email him at blinsell at dstvdm dot com
This is custom firmware. What they mean as Google Certified is the device, not it's firmware. We could guess that H96 Pro+ are certified, coz they came with GApps in their official firmware.
However problem is that till now Google didn't need to certify device for GApps to be part of its firmware. Last updates (not sure if security ones or Android 8.1) brought the need for the device to be in Googles database and it even broke some users with custom roms access to Google Services (but here it can be easily restored).
As fot SafetyNet, than even with MAGISK You should be able to pass it. Xposed will break it, but not just MAGISK and it's less invasive modules,
Unfortunately our devices are not Certified. It can be checked in Google Play Store's Settings. And no, You cannot certify it Yourself. It had to be done by manufacturer...ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostThis is custom firmware. What they mean as Google Certified is the device, not it's firmware. We could guess that H96 Pro+ are certified, coz they came with GApps in their official firmware.
Hi all,
First of all thank you Superceleron for the great work you do.
I installed the AlfaWise H96 PRO + 3 / 16Gb - 3 / 32Gb - 3 / 64Gb - SCV4A-ATV 7.1.2 (DDR3 / DDR4 - ANDROIDTV VERSION) on a Smartbox X92 3G / 16G - Octa Core 64bit Cortex -A53 - DDR3 everything works fine except the wifi. Would anyone have an idea to fix this problem please.
Thanks in advance and sorry for my bad english
There are currently 1674 users online. 1 members and 1673 guests.
