if you want you can move the discussion
SO we should write in the thread of SCV7A.
As for updating it have to work. It worked for me nad for many other users... I did V4 using USB Tool. Than boot the rom and set up date, time and my account (all what first setup wanted). Than booted TWRP and flashed both V7A and MAGISK (right after)... There were no problems...ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
it is correct to move.maybe I did something wrong. I flash the rom with v4 with sdcard. I started the box changed language. time and date. then I formatted sdcard on pc and copied the zipped v7 file.then with ota did not work then I asked for help to you and you explained to me to start twrp and then you know how it went wrong 1.
I did not do anything else
Seems You have all the steps covered. Not sure where could be a problem. Maybe flash V4 once again?
And maybe move here with Your questions: http://freaktab.com/forum/tv-player-...7-wifi-chipset
As this is the rom You have problem.
At the beginning MAGISK was just an systemless rooting solution. Now it's whole mod with possibility to launch other mods systemlessly.
hi
I'm sorry if it is the bad place to post it... i'm new and french ;-)
i installed the SCV4 ATCV on my H96 pro+ 3/32
it works great
good job
but.. there is a but
when i want to shut it down ( i modify the key in parameters for shutting down) my H96 stop and seems to be in a standby mode because the red light stay and no possibilities to wake it up with my remote control
Is it normal and what is the solution.
with the original firmware it stopped and waked up with the remote control
thanks for help
PS: Same thing with the SCV7
Hello everyone, let's see if you are able to help me.
I have H96 PRO + 3 / 32GB - DDR3 ZH01-S912-TVBOX3.0 and I can not update with this firmware. (Superceleron).
I only managed to update with Wisdom Pro + Firmware H96 (aml_7.1.2_s912_q9377-H96PROPLUS_mac-20171120)
When updating with "SCV4-A7.1.2-x64-Alfawise.H96.ProPlus.img" always gives me an error 0x10302001
Any ideas?
kiki16
Flash MAGISK in TWRP. Not sure if Total Commander supports Root (it should), I'm using Solid Explorer Classic and 2.0 (new one with Material Design).
ramogi
I'm using Normal rom. More apps are supported by Play Store and ATV ones can be installed using apk and APKMirror. And it's easier to change launcher - no problems like with ATV.
I'm using HALauncher. Wouldn't use it on smartphone or tablet, but for TV Box it's amazing.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View Post
ramogi
I didn;t mean Android TV as OS, but it's apps.
E.g. here is Netflix TV: https://www.apkmirror.com/apk/netfli...ix-android-tv/
And here YouTube TV: https://www.apkmirror.com/apk/google...tv-android-tv/
They are not available through Play Store on Normal rom (available are only normal apps), but installed using apk file are working fine (except Netflix app still doesn't work coz of to low level of Widevine, it's just an example).
Additionally I installed Pushbullet and added ATV apps I installed that way and it notify me every time there is update. It won't install it, that and download have to be done manually, but at least I know there is somethingALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 2749 users online. 0 members and 2749 guests.
