Ok. I just say what I read. Many users, however not on this forum, wrote that MyCanal seems to have problem with missing Widevine DRM. And as that's difference between Beelink GT1 and M8S Pro L and W.
Originally posted by dangchui View PostOK i come back with my try i have installed magisk on recovery ok all led of magisk manager IS OK
on magisk APP
i go to magisk hide and i coch mycanal
i try MYCANAL 3.5.4 And it s idem prb of videos there s audio
Hi all, i m new in this forum, first Time thanks for your very good job! I have 2-3 questions. Alfawise H96 pro + 3/32
I own a micro SD Samsung SDHC 16GB When I try to create a boot card by forming in FAT32 I get an error but the installation arrives successfully in NTFS. I will try from another computer but the installation is possible in NTFS format ?
In the eventuality or the installation of ATV would be a failure is it possible to reflash with a stock Fw ?
Stock Fw all identical ?
Is it possible to install a non-ATV application that is also only performed in portrait manually through a file Manager
Can you possibly make available or send me a list of the version of the H96 Pro + that works and the versions that are not at all compatible with the ATV Fw.
I did not manage to actually understand which serial number was to be avoided especially on the green PCB can you enlighten me? Unfortunately I can not give you my number yet I wait for the box by next week. But it could help the tutorial
Thanks advance.
Hello. I need someone help because my YouTube app now read all text like talkback functions and can't disable this function. This read name of video, read visualizations video and almost everything its very annoying. Can't find how can i disable this. Please if someone can help me i thank you so much. Now this is happen in my mi box 3 international and YouTube TV app. Please help me.
thanks
Hello superceleron, first of all thanks for your fantastic work. Before installing ATV I need some information. Is it possible to do a back up before proceeding with the ATV installation? I see that there is a firmware stock but is it identical for the Blue PCB version and green? I'm really interested to go under the ATV Fw but I'm a little afraid to make my box unusable. I read that there was a version of the H96 not compatible how to recognize it ? In case of a pendant installation ATV error and it possible to reinstall directly the FW stock? I am used to all kinds of installation, Windows, Linux, Mac, Android x86, Hackintosh. But for Android installation there is little information can enlighten my questions please. Thank you in advance.
Morgan5000
Here:https://mega.nz/#F!8qhRRaYJ!2ZA3VLjvLT6wg0IwsTF27g are images for most of H96+ variants.
There are images for both green and blue PCBs, but they are not same ones. Images in folder for S32-V5 and S32-V6 are for blue PCB and rest are green.
Additionally You can use this TWRP image: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I to make a full backup of the stock firmware You have right now.
Just copy it to SDcard (or USB flash, however I'm not sure it will work), than disconnect power cord, start pushing reset button, connect power, keep pushing for ~5 seconds. Then it will boot to TWRP.
In case of error You may use same method You will use to flash this rom, to flash stock firmware. It can be done on Windows (USB Burning Tool) or using SDcard method (any OS, as You need it only for burnint the image to SDcard).ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1910 users online. 2 members and 1908 guests.
