Very fast answer ... But dear superceleron can you help me explaining me differences between android tv versione and normal one ? Which are the advantages , if any , of android tv version? Should I stay on SCV1 or go to SCV4 ... Again many thx for your patience
https://androidtv.news/2016/07/andro...mart-tv-boxes/ for the benefit of those that , like me , don't know the differences .
I'll stay on android tv rom scv1a
Thx
Dear superceleron
I'm testing this room in a box r-tv box s10 3G dd4 / 32G and is behaving very well, however the original IR control does not work. Is it possible to insert support for the original r-tv box s10 control in an upcoming release?
Congratulations on the work, this room has transformed my box into a much better equipment. The original room is very bad
Best Regards
Originally posted by wolfsstolz View Posthmmm i have flash it now and the only is that i become a blue screen. I have only see first time for a half secound a Android Update screen, then come the bluescreen (no HDMI i think). I have now make a restart (power of) but only bluescreen, Reset dont work. Anybody know what can i do now !? Thanks
Edit://
now i have inside a SD card with old FW (Stock FW) and have start an upgrade process with bluescreen and have wait for an half hour. if i look again to the box i see the Stock FW is flashed back again
But the problem will be ... How can i flash now a custom rom !?
on this box i had to let the toothpick pushed in the hole durring all the upgrading process. (2 minutes approximatively). it's weird but it works
Best Regards
Originally posted by Yves-Marie View PostBug (V1) : activating bluetooth in "More settings" hangs.
i have read that "more settings" items hangs on V1 bugs list but is there a way to activate bluetooth ?
Hi, super celeron,
Thank you for the Rom and was just wondering will this Rom work on box R-TV box S10 3G dd4 / 16G. am sure people who have experimented (like scooter2014,veniciusgp) on this box would be better to comment .any guidance in this regard would be welcome to me.thanks in advance.
There are currently 1608 users online. 0 members and 1608 guests.
