If after the 2º flash still no go, reflash stock again.
check the md5 of the zip, and flash again... is your box a real h96? or a clone?
Originally posted by amitabh15v View Post
Its a real H96+ 32gb/3gb DDR3. I've been running your previous marshmallow ATV rom since you launched it. Upgrading now to 7.1.2 to get magisk and netflix. I will try and flash again and post results.
Hi Super Celeron, Thanks for your great efforts on behalf of all non programers.
I have the H96 Pro Plus and a Measy GP811 air mouse controller. Both of these seem to be very common products, in one guise or another, as a Android TV solution.
Which of your Roms would be best? Can it be installed using the USB - IMG method? Will the GP811 work properly?
Thanks again for your efforts.
Originally posted by bfh42 View PostHi Super Celeron, Thanks for your great efforts on behalf of all non programers.
About the best rom... well is your choice i cant tell you the best one, is a matter of taste!
USB-IMG? you mean usb burning tool? if is that then yes...
There are currently 2954 users online. 1 members and 2953 guests.
